Old 06-26-2008, 08:21 AM
Bill Payne Bill Payne is offline
EIFS Help
I inspected a house with what I believe to be stucco covering the foundation walls to grade and EIFS on framing. Not sure if these (photos) are EIFS weep holes. They are installed at a uniform height and spacing spanning the entire wall. They look to be right at or above the floor plate.
Thanks,
Old 06-26-2008, 10:53 AM
John Carroll John Carroll is offline
Re: EIFS Help
Bill,
First off, where is this at?
Secondly, it's not typical to see a lace or skip trowel texture with E.I.F.S in general, altho it's possible, depending on where you're at. Unless you are certain on your identification, I'd recommend having an expert look at it.
In general, taking any cladding completely down to grade is a bad idea because it gives the wall a constant source of moisture from which to draw, never a good thing. The holes probably are for drainage, but that doesn't remedy the above problem.
How old is this building?
If relatively new(2yrs) it probably hasn't had time to show any damage that is probably occuring behind the cladding. If IR testing shows a problem in the making, your course should be clear.
When in doubt, refer an expert.
I'm a dyslexic agnostic-Don't believe there is a dog...
Old 06-26-2008, 07:38 PM
Re: EIFS Help
Thanks,
Property is located just north west of Austin TX. Built in the late 90s. Walls are hollow sounding, foundation sections are very solid. I have inspected EIFS before but this one is different as you mentioned.
Old 06-26-2008, 07:45 PM
Re: EIFS Help
Quote:
Bill,
Maybe it is an ICF house?
ICF (Insulated Concrete Forms) houses have a hollow sound and would go (should not, but typically would) down even to the foundation as shown.
That would feel solid at the foundation/slab and sound hollow above.
They also have stucco with a texture like that too.
Old 06-26-2008, 07:51 PM
Randy Clayton Randy Clayton is offline
Re: EIFS Help
From those photos it apears to me that it looks as if they were anchor bolt holes not drains. There should never be any holes;especially on efics sytems on the sides of the structure.
  #6 (permalink)
Old 06-26-2008, 07:57 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Re: EIFS Help
Quote:
Originally Posted by Randy Clayton View Post
From those photos it appears to me that it looks as if they were anchor bolt holes not drains.
Decorative Lighting Holders.
Billy J. Stephens HI Service
  #7 (permalink)
Old 06-26-2008, 08:11 PM
Re: EIFS Help
so what do you think? you said nothing though I think you said enough.
  #8 (permalink)
Old 06-26-2008, 08:23 PM
Re: EIFS Help
Any one else noticing this trend which has developed here recently (last few months or so) where, if one does not like another's post, they post a snide comment about it?
The above is just one example of what has been going on which did not used to go on.
Seems like some are just not good at 'plays well with others' in the sandbox here.
  #9 (permalink)
Old 06-26-2008, 08:36 PM
Re: EIFS Help
The Posted Picture is what the holes look like to me.
Plastic Anchor's most likely put there by the home owner to hang his/her Christmas decorations or other festive outdoor items.
Decorative Lighting Holders ( Was A Statement = Saying something.)
  #10 (permalink)
Old 06-26-2008, 08:40 PM
Re: EIFS Help
Jerry,I do not know if you were inquireing about me?
Iwas just stating the facts if Bill saw what i saw and i think he did and needed no further explanation!
  #11 (permalink)
Old 06-27-2008, 09:47 AM
Re: EIFS Help
They might be wall anchors, maybe an inquiry to the previous owner might shed some light...In any case, you should make mention and cite local or IRC code about the stucco below grade. I'm pretty sure there is no exception for IFC walls to this, but you should check the local codes in case.
Even if they allow it, it's not a good idea because it will lead to a weakened system over time.
What did they do at the slab locations at the entry or patios? Do you have any other pictures?
  #12 (permalink)
Old 06-27-2008, 08:38 PM
fritzkelly fritzkelly is offline
Re: EIFS Help
Why do you think this is EIFS? Because it sounds hollow? Most stucco I see has rigid foam behind it and sounds hollow when rapped. It doesn't look like EIFS to me from the pictures.
  #13 (permalink)
Old 07-03-2008, 10:41 AM
carl brown carl brown is offline
Re: EIFS Help
Onecote stucco.
Home inspection
Similar Threads
Can you tell me if this is EIFS Seth Hughes Building Envelope: Home Inspection and Commercial Inspection 19 09-07-2008 05:40 AM
EIFS, another aspect for thought Jerry Peck Building Envelope: Home Inspection and Commercial Inspection 7 05-20-2008 12:37 PM
GAHI EIFS Protocol Aaron Miller Building Envelope: Home Inspection and Commercial Inspection 4 03-09-2008 02:03 PM
Identifying hardcoat stucco & EIFS Scott Dana Building Envelope: Home Inspection and Commercial Inspection 50 01-28-2008 03:08 PM
whats does eifs look like daniel nantell Building Envelope: Home Inspection and Commercial Inspection 9 11-17-2007 12:29 PM
vB.Sponsors
Ad Management by RedTyger
