Old 07-21-2008, 11:17 PM
mathew stouffer mathew stouffer is offline
Masonry over siding material
This is a DIY. The siding is an old particle board siding almost like OSB. The owner is installing stone over the siding after installing a building paper (15min paper). Any thoughts.
Home inspection
Old 07-22-2008, 09:19 AM
Re: Masonry over siding material
Wow, it would be interesting to see how he treats door and window openings. Seems like he watched too many HGTV shows.
- are the wall ties galv or stainless
- are the nails galv or stainless
- that looks like regular chicken wire not the wire mesh generally used for various types of veneer work
- did he actually pour any kind of foundation under the stones
- is he using an admix in the mortar
- there doesn't appear to the an air gap between the stone wall and org wall. Natural stones can suck up a lot of water. 15# felt isn't going to hold up long. Should be an air gap and tyvek type paper.
- has he given an thought to drainage
- has he consulted with anyone on his mortar mix composition
- is it going all the way up
- WHY?
Just some initial thoughts
Markus Keller
Old 07-22-2008, 11:33 AM
Quote:
Originally Posted by mathew stouffer View Post
Any thoughts.
Tear it off and do it right.
Home inspection
Similar Threads
reinforced masonry vs un-reinforced masonry Jerome W. Young Structural Components: Home Inspection and Commercial Inspection 8 04-02-2008 01:49 PM
How dod you write up masonry parge coatings? Ross Neag Building Envelope: Home Inspection and Commercial Inspection 6 03-30-2008 04:48 PM
New Siding Material Aaron Miller Building Envelope: Home Inspection and Commercial Inspection 1 03-24-2008 04:44 PM
Masonry Foundation Supports ROBERT J MOUNTAIN Sub-Structure: Home Inspection and Commercial Inspection 2 11-27-2007 05:35 PM
Valley material David Banks Roofing System: Home Inspection and Commercial Inspection 9 06-17-2007 03:02 PM
vB.Sponsors
Ad Management by RedTyger
