Thread: Storm window at interior
05-22-2007, 04:40 AM #1
I came across an older house that had almost all new windows. One of the windows that was not new had a storm window at the interior wich prevented the window from opening.
This is a first for me and I was wondering how others would report it.
05-22-2007, 05:30 AM #2
Re: Storm window at interior
Definite egress issue.
05-22-2007, 06:20 AM #3
Egress issue IF it is the only window in a bedroom with only 1 door. Otherwise just a defective window operation.
05-22-2007, 06:22 AM #4
In need of repair, water entry is likely. The window does not open, so it is not functioning as intended.
Double whammy (technical term) if it is a window needed for egress from a bedroom.
05-22-2007, 04:40 PM #5
Triple whammy ...
No natural ventilation as required either.
By the way, the 'two doors' does not solve the problem either - there needs to be two 'paths' (means of egress) in opposite directions. Two doors, opening into one hallway, going to the down stairs does not fulfill that requirement (option).
05-22-2007, 08:10 PM #6
Okay, my English as a third language issue is rearing its head again. 'splain to me please, the issue of a door to the outside in a sleeping area not sufficing for emergency egress. Thanks.
- Paul Fix
05-22-2007, 09:18 PM #7
'Cause that's not what was said.
This is what was said: "Egress issue IF it is the only window in a bedroom with only 1 door."
Nothing in there about "door" + "to" + "outdoors/outside".
Just "1 door". There could be 2 doors, neither leading directly to the outdoors.
Capice? (speelin'?)
05-22-2007, 09:38 PM #8
Capiche (sp?)
- Paul Fix
