Results 1 to 11 of 11
Thread: fire breaks
04-06-2009, 03:25 PM #1
fire breaks
If you cut a hole in drywall about 1/2 sq ft for access to a shut off valve and don't put a access panel door on it, doest that create a fire break issue?
If it is a fire break issue, can you put a cheap thin plastic cover panel over it to correct it?
04-06-2009, 03:29 PM #2
04-07-2009, 03:01 AM #3
04-07-2009, 05:27 AM #4
Re: fire breaks
John,
First is a question: What are you talking about cutting a hole in (what wall where)?
In a dwelling unit?
In a wall in a townhouse separating one townhouse from another townhouse?
In a non-dwelling occupancy (such as a "store") in a wall separating one "store" from another "store"?
04-07-2009, 06:49 AM #5
Re: fire breaks
Most firewalls are allowed to be penetrated up to 100 sq inches of area. Or you used to be able too. Really haven't looked in a while! UBC
04-07-2009, 07:08 AM #6
Re: fire breaks
Correct as far as you went.
100 square inches in a 100 square foot area, provided listed electrical boxes are used, listed for use in a fire-rated wall (typically listed for use in 'up to' a 2 hour rated fire-rated assembly).
Once you cross that threshold, or when boxes are within 24" horizontally of each other, then "opening protectives" are required to be used. The most common "opening protective" is the putty pad, and 80-90% of the time the putty pads are improperly installed (at least that I've seen).
The first attached shows the inside of a Slater box, the second attached photo shows a zoom in to the rating in the upper right hand area in the back of the box.
04-07-2009, 07:12 AM #7
Re: fire breaks
Hey Jerry, I had to leave something for you to say! You know how quiet you are!
04-07-2009, 11:13 AM #8
Re: fire breaks
For example, an interior wall in a closet that houses a gas fired water heater. See pic.
04-07-2009, 12:10 PM #9
Re: fire breaks
That's not a fire wall so there is no "fire break" issue, however, it certainly could cause/create both an energy code issue and combustion issues, not to mention accessibility issues to that valve.
04-07-2009, 03:37 PM #10
Re: fire breaks
John, Is that the combustion air intake port for the water heater? Seen that before, alot!!! IS there an attic above ?
04-07-2009, 04:56 PM #11
