Results 1 to 11 of 11
Thread: Moisture level in Crawlspace
04-16-2009, 01:03 PM #1
Is anyone aware of the "allowed" moisture level in a vented crawlspace in North Carolina? I would appreciate a reply as soon as someone is available. I have not been measuring a moisture level. Thank you.
04-16-2009, 01:25 PM #2
Re: Moisture level in Crawlspace
04-16-2009, 01:50 PM #3
My guess would be the RH of the air, which should be close to, and probably slightly more than, the air outside the crawlspace (unless it was raining or has recently rained, in which case the air outside the crawlspace probably has a higher RH.
Now, if there is a moisture related problem, then regardless of what it is, it is "too high", the solution would be to find the cause the make corrections based on that.
04-16-2009, 01:55 PM #4
Thank you. It is the RH that is being measured and the stat is set at 50 and will turn off when adjusted to 65. I am suspicious that there was a "previous problem". The ground under the vapor barrier is completely dry and there is no sign of any moisture on the wood framing.
04-16-2009, 02:08 PM #5
04-16-2009, 03:10 PM #6
No, Jerry.
04-16-2009, 03:57 PM #7
04-16-2009, 04:23 PM #8
04-16-2009, 05:12 PM #9
You are not being real clear. I am guessing there is a humidistat controlled ventilation system. Difficult to offer help when the information provided is incomplete.
04-17-2009, 07:34 AM #10
Try this website. They have a great amount of information on crawl space environments. They are out of NC.
Advanced Energy
04-17-2009, 09:11 AM #11
Thanks to everyone. I appreciate the help. Thanks especially to Scott for the link to the website. It is invaluable. Danny.
