Thread: Water Heater Closet Door
08-18-2009, 09:58 AM #1
The water heater is located in a garage closet with the ceiling open to the attic (1999 home), no combustion air tubes.
The water heater closet door is approximately 1/4 " thick piece of plywood, using a door hing & bolt to lock it. There are gaps around the door edges.
Would this type of door configuration be consider okay, proper?
Brian
08-18-2009, 10:01 AM #2
Re: Water Heater Closet Door
Does not even need a door, so anything would work ... and no, I did not say "anything" would look professionally done.
Read this thread: http://www.inspectionnews.net/home_i...om-garage.html
08-18-2009, 12:45 PM #3
Just make sure it is off of the floor by 18" to any spark/flame/ignighter etc.
08-18-2009, 01:27 PM #4
and Brian, is the area over the water heater closet that's open to the garage attic also open to the attic over the home?
08-18-2009, 06:04 PM #5
If the attic is common to the garage and house, there needs to be a separation somewhere. From your description, it is not right.
