Thread: door tread or landing
06-08-2007, 06:45 PM #1
06-08-2007, 08:47 PM #2
Re: door tread or landing
Dan,
Just because a landing is *not required* by *minimum* code does not mean that one is not allowed to install a landing.
Of course, though, *if* that is a landing, then it must meet the requirements for a landing, and, if not, with the size of it, I would state that the landing (that's what it looks like it is supposed to be to me) is not in conformance with the requirements for landings and could cause trip and falls.
It also has a handrail which is not required, and which does not appear to be in conformance with the requirements for a handrail.
Are the risers heights the same or within the 3/8" maximum riser height variation allowed?
Open tread risers should not be more than 4" open either.
The garage door operator button looks to be a bit low too.
06-08-2007, 09:31 PM #3
And tell Big-Foot to move his shoes from in front of the incorrect handrail.
- Paul Fix
06-09-2007, 09:35 AM #4
Does not have a return at the top, and most likely at the bottom.
Needs to be "graspable" on both sides of the rail. In the photo it looks like only one side is "graspable". It could be both sides but it does not look like it.
Without really seeing it in person I would also say that the rail needs to start at the landing and not at the step. If it was me, I would have built the handrail on the other side of the steps, it would have made it safer.
Not required because of the number of steps(risers)
06-09-2007, 10:55 AM #5
I looks to me that the handrail was put there to hold onto while they removed thier shoes.
06-09-2007, 11:00 AM #6
