Results 1 to 13 of 13
Thread: separation wall/tape and mud?
11-03-2009, 06:09 PM #1
I've been looking around the boards and can't seem to find an answer to this: does the separation wall/ceiling between the attached garage and living space need to be taped and mudded? Or is just have the proper sheetrock up enough?
11-03-2009, 06:19 PM #2
Re: separation wall/tape and mud?
Well, that is somewhat of a simple but complicated question and answer. (not to be a smarta$$).
So let's say your municipality requires a 2/3/4 whatever hour separation. There are various ways one can achieve that X hour wall. How that wall is achieved is often times dictated/referenced by a UL listing #. Your Muni may even reference a particular UL. The UL spells out the type, layer composition, thickness, amount of screws and tape joints in order to achieve that wall rating. That is essentially the legit way of complying with a firewall separation. You state you built the wall according to X UL standard, thank you very much.
The short answer is, No. Without being taped the wall does not comply. I've never read a UL wall listing that didn't require taping. And yes, I have read quite a few.
Hope that helps.
11-03-2009, 06:25 PM #3
11-03-2009, 06:28 PM #4
Because it is not a fire-rated assembly it is not a fire wall, just a separation wall, however, unless it is taped at the joints then there are gaps, and the gaps would violate the separation wall.
It does not have to be taped pretty, just bedded and taped, in fact only just bedded and taped with no joint compound over the tape to meet absolute minimum requirements, of course, though, it is very difficult to bed and tape without also spreading some joint compound over the tape in the process.
11-03-2009, 06:42 PM #5
Ok, so I completely over thought this one.
11-04-2009, 10:32 AM #6
the wall does not require taping if all the joints land on solid framing. you would have to install the drywall with the long dimension parallel to the studs.
11-04-2009, 06:03 PM #7
11-04-2009, 09:59 PM #8
11-05-2009, 07:42 PM #9
If those are "fire walls" or "fire partitions" between dwelling units and not just "draftstopping" walls in the attic of a single dwelling unit, they are all completely wrong.
"Repair" would be costly to do it properly (if Canadian building codes require anything like US building codes do).
11-05-2009, 08:28 PM #10
11-05-2009, 08:52 PM #11
Because it is not anything like this: http://www.gypsum.org/pdf/225-08.pdf
11-12-2009, 06:32 AM #12
Boy they must sell screws for a living also
02-07-2020, 09:52 AM #13
I know I am jumping in very late, but I have a solution for any wall that would normally need to be taped and mudded. The product is called E-Z Tape Flame Fighter drywall tape. It is 1 and 2 hour rated for ceilings and walls and does not need mud to pass. it is certified by Intertek and has been around for 20 years. It is not for finishing in an area that needs to look pretty, it is pink and definitely stands out, but in an attic or utility room it works great.
