Thread: Chinese Drywall
    sam sanders's Avatar
    sam sanders Guest
    Default Chinese Drywall
    I read that the problems originally associated with imported drywall has now been expanded to domestic as well. Other than checking for any suspicious corrosion on the copper and brass fixtures in the house, has anyone heard of a reliable test, or come up with a decent referral for clients? Even if the house showed no suspicious corrosion, if it was built or remodeled after 2003, it could still contain some defective drywall. I live in the Southwest. Evidently, due to the low humidity, symptoms could manifest years down the road. What kind of CYA statements have you guys come up with?
    Default Re: Chinese Drywall
    Check out past threads here and the Florida dept. of health website.
    Beware, there are all sorts of snake oil salesmen coming out of the wood work on the internet!
    Quote Originally Posted by sam sanders View Post
    If you are in a licensed state, most likely the state law/rules cover you already. It is a latent defect, and is also considered an environmental problem. Just about every state law protects home inspectors against this.
    I have not changed a thing in my agreement, it pretty much covered items I have no control over, I can't see or is a latent defect.
    Ron Bibler's Avatar
    Ron Bibler Guest
    Did any one ever get a list of the states with this type of sheet rock?
    Best
    Ron
    SANTA ROSA PEST CONTROL .COM
    Quote Originally Posted by Ron Bibler View Post
    Check the maps on this page: Imported Drywall
    Go here
    Imported Drywall
    for a map.
    chris mcintyre's Avatar
    chris mcintyre Guest
    Today 06:43
    Today 06:47 PMJim LuttrallGo here
    Imported Drywall
    for a map.
    And the winner is.........................Jerry! by 4 minutes.
    sam sanders Guest
    Thanks, I'll read the old threads. I was curious about the CYA angle because It was recently added to the Buyers inspection notice paperwork for Realtors in my state (Arizona). I'll check with my cert board.
    Sam
