02-06-2010, 06:10 PM #1
Garage door sprint safety cable requirements
Do all unrestrained vehicle door coil springs require a safety cable, or only certain types?
I didn't get a picture of this entire spring arrangement: off to the right, the end of each spring is attached to one end of a short length of cable. The cable runs through the sheave of a pulley, which has a second cable attached to the pulley's strap, this second cable makes the connection to the door.
It's hard for me to imagine how a safety cable could be inserted through the springs without interfering with their operation, OTOH things could certainly get nasty if a spring or its connection point failed.
I did not note the identity of the door operator's manufacture so I can go back to their instructions,.
Is anyone familiar with the safety cable requirements for this arrangement?
Thanks.
Similar Threads:Last edited by Michael Thomas; 02-06-2010 at 06:33 PM.
02-06-2010, 06:51 PM #2
Re: Garage door sprint safety cable requirements
I don't believe they are required in MN, however I always recommend them when I see they are not installed.
02-07-2010, 10:56 AM #3
I use this when questioned about safety cables in extension springs.
http://www.dasma.com/PDF/Publication...ial/TDS151.pdf
If a man empties his purse into his head no one can take it away from him. An investment in knowledge always pays the best interest
Benjamin Franklin
02-07-2010, 12:23 PM #4
02-08-2010, 07:42 AM #5
There should be a safety cable running through the spring(s).
Had a spring break in my own home a couple of years ago, the spring with the cable did a lot of damage to the support brackets, don't even want to think about what would have happened if the cable wasn't there.
