Results 1 to 14 of 14
Thread: Staining on surfaces
03-26-2010, 12:00 PM #1
Had a house yesterday that had a bunch of various shaped oval staining on window trim, wood surfaces, and wood trim at walls and openings. Moisture meter did not pick up any abnormal readings above the lowest parameters in the green. Anyone ever seen this or have some thoughts. Thank you for your comments in advance.
03-26-2010, 12:02 PM #2
Re: Staining on surfaces
Forgot photos. My bad.
03-26-2010, 12:06 PM #3
They look like knots in the wood that wasn't primed correctly.
03-26-2010, 12:39 PM #4
03-26-2010, 01:25 PM #5
I concur, knots in the wood with only a single coat of paint.
03-26-2010, 02:19 PM #6
Just to check, you're a home inspector not a homeowner?
03-26-2010, 03:36 PM #7
03-26-2010, 03:47 PM #8
03-26-2010, 03:49 PM #9
03-26-2010, 04:04 PM #10
03-27-2010, 05:06 AM #11
Sometimes HO's come here and ask questions and the answers we give should be tailored to their skill level.
03-27-2010, 04:45 PM #12
Aaron,
Keep in mind that some home owners know more than some home inspectors, and that home inspectors/builders/contractors/code inspectors/architect/engineers/etc are also "home owners".
Until a lack of knowledge is displayed, all should be treated the same - as being able to understand what is discussed here.
03-27-2010, 06:49 PM #13
I concur. I believe it is incumbent upon the reader of ANY professional board to be able to understand what is being disseminated there. However, ALL skill levels may be represented by HI's on this board as well.
Beacon Inspection Services
Like Beacon On Facebook
03-27-2010, 07:26 PM #14
