Thread: Window Condensation
03-31-2010, 07:42 AM #1
Window Condensation
There seems to be a moisture issue here but I was not able to pin point the cause.
Any thoughts would be appreciated.
No humidifiers in use, only happening at one corner bedroom facing north and east. I'm thinking possibly from the window treatments??
03-31-2010, 08:00 AM #2
Re: Window Condensation
Is this the only window in the home that is doing this?
Best
Ron
03-31-2010, 08:03 AM #3
It is happening only at 2 windows in the same room. This one appeared to have condensation between the panes where the other window did not but still had signs of moisture at the surrounding area.
03-31-2010, 08:20 AM #4
Moisture between the panes is not a condensation issue of course.
Is this in a bedroom by chance? Perhaps several occupants sleep in this room, which will cause a high moisture content in the air. If this is a master bedroom, then the moisture would have come from sleeping occupants as well as from the bathroom.
03-31-2010, 08:42 AM #5
It is a small bedroom, no bathroom, I believe 2 elderly occupants.
03-31-2010, 10:16 AM #6
Lots of things can cause excess moisture. Cooking, breathing, a backventing furnace. If only in one room and that room is being used, probably breathing. If older people, maybe they are using a humidifier.
03-31-2010, 11:18 AM #7
If they are keeping the drapes closed at night it could definitedly cause condensation, and should evaporate soon after the drapes are opened.
04-16-2010, 09:25 AM #8
I see this topic is a few weeks old, but I figured I'd throw this in anyway.
Any idea what the humidity level was in the house? I observed a house once with a very high, concentrated, moisture content that was actually created by an over-pressurized hydronic heating system. This was introducing moisture into the bedroom, creating moisture on exterior walls and on the inside of windows. Just a thought.
I would find it hard to believe that breathing alone would introduce enough moisture to raise the dew point in that room that much.
