Results 1 to 10 of 10
Thread: Stairs
    Ryan Stouffer's Avatar
    Ryan Stouffer Guest
    Default Stairs
    I know there has been plenty of discussions about stairs on the site before. This set of stairs has 4 risers and a handrail but it is 29 3/4 high. Should it have a guardrail?
    Thanks,
    Ryan
    Default Re: Stairs
    Should it have a guardrail? Yes.
    Is a guardrail required? No.
    chris mcintyre's Avatar
    chris mcintyre Guest
    Default Re: Stairs
    Quote Originally Posted by Ryan Stouffer View Post
    Thanks,
    Ryan
    Post # 7...
    Darren
    You may be confusing "handrails" and "Guards"
    Guards are required on the open sides of stairs, porches, ramps, and decks if 30" or more above the lower surface.
    A(only one)handrail is required when there are 4 or more risers in a stairway, reguardless of height above the lower surface.
    On this thread...
    http://www.inspectionnews.net/home_i...handrails.html
    Default Re: Stairs
    Thanks,
    Ryan
    I would write this as a Safety Hazard .
    *aunt Martha don't Look Good in a Body Cast.
    Default Re: Stairs
    Post # 7...
    On this thread...
    I don't follow what you are getting at, can you explane it to me?
    Default Re: Stairs
    I knew I had seen the answer somewhere, and now I see that you made your post while I was quoting your other post from another thread.
    I guess what I am trying to say is you were right....both times.
    Default Re: Stairs
    Gotcha.
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Re: Stairs
    Let me put it in simply terms a slow man like myself can grasp. It is equipped with required handrail. No guard rail because one is not required.
    Default Re: Stairs
    And they put cardboard boxes there to cushion the fall when you walk straight out and off the end.
    Default Re: Stairs
    Yeah,
    But they Got Those Painting Imperfections on the Finial Walk Through.
