Thread: What is this
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default What is this
    Any idea what this is. It was simply bolted to the wall. I was just curios what it may be used for. In a bedrooom condo built in 1983
    Edward Loughran's Avatar
    Edward Loughran Guest
    Default Re: What is this
    Wall mount for a television?
    Its used to secure the goats too.
    What
    Seriously, its a mount for a flat panel television.
    Usually, the drywall around the television area will have numerous openings present where Bubba was trying to fish the cable wiring down the wall and missed 9 times. Wall receptacles behind the television will usually test as a open ground or hot and nuetral reversed also.
    Oct 2009
    Birmingham, Al.
    I like the TV mounting bracket too, but not a flat screen. It looks like the type previously seen in motels and hospitals prior to flat screens.
    Robert Welch's Avatar
    Robert Welch Guest
    Quote Originally Posted by Edward Loughran View Post
    I agree, a TV mount for an older TV, we used them in hospitals for years, allows them to pivot 180 degrees.
    Robert
    Houston Home Inspection - Robert Welch - Houston Home Inspector
    Tom Comstock's Avatar
    Tom Comstock Guest
    Yep,, had one in my bedroom once.
    Tom Comstock
    Tex-Pro Residential & Commercial Inspections in Houston, Texas
