Results 1 to 3 of 3
Thread: door landing?
07-06-2007, 09:21 AM #1
door landing?
07-06-2007, 09:32 AM #2
Re: door landing?
What does this door serve? If it's a pool equipment of mechanical closet, the I probably would not make an issue.
If it is a path of egress then yes a landing, at the same level as the floor (1/2" difference), would be required.
Try the door yourself and see if you don't trip or twist your ankle...remember not to look down since you know it's there.
07-06-2007, 11:17 AM #3
Re: door landing?
Door should not open out over a step. This is a trip and eat $&*$ hazard.
