Results 1 to 18 of 18
Thread: Question RE: Egress
05-21-2010, 09:39 AM #1
Question RE: Egress
Does the IRC offer a more in depth definition of a sleeping room? I have a dwelling that has a room, looks kinda like an office actually. There is a fixed window, but not an operable one. Seems this room has the potential to become a sleeping room should the new buyer wish, but I cannot predict what they will use it for. Appears to be a potential situation for entrapment with no escape. Sleeping area (currently) or not.
R310.1 Emergency escape and rescue required. Basements,
habitable attics and every sleeping room shall have at least one
operable emergency escape and rescue opening...
Similar Threads:Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
05-21-2010, 09:48 AM #2
Re: Question RE: Egress
Is there a fire suppression system, by any chance?
I ask because I recently inspected a relatively new townhouse with a finished basement with no secondary egress.
The local code guy told me they'd made an exception for townhouses that had fully functional fire suppression systems (it appeared to), inter-connected smokes (it did) and a fire extinguisher of a certain size within 5 feet of the bottom of the basement steps (it didn't).
I guess what I'm trying to say is that it's possible the room is ok depending on the circumstances.
05-21-2010, 10:32 AM #3
marc,
what was the room originally designated as? try not to predict what it could be.
05-21-2010, 11:20 AM #4
05-21-2010, 11:30 AM #5
05-21-2010, 11:37 AM #6
o.k. john i'll play! assuming in the inspection gig can lead to misunderstandings with consequences. when the approved plans call the space a library,den,hobby room,media room,sewing room, storage room, adult toy room, or whatever room, we check it for compliance with the use. just because it has drywall, paint, smoke alarms, and it is conditioned still it is not a sleeping room.
with your statement a bathroom or a closet could be considered a bedroom, their finished and conditioned!
a bedroom needs an eero,smoke detectors, and in someplaces a closet but it should be designated as a bedroom on the plans!
05-21-2010, 12:28 PM #7
05-21-2010, 12:59 PM #8
05-21-2010, 01:42 PM #9
This room was 10x10 ish, and has a door. If a fire started in the hallway, and your in the "office" (not a bedroom), there would be no means for escape. I suppose you can shut the door, and hope the 1 3/8 hollow core door keeps the flames at bay looking out the window wishing you were out there. BTW, the room is on the second story.
05-21-2010, 01:55 PM #10
05-21-2010, 02:27 PM #11
05-21-2010, 02:32 PM #12
05-21-2010, 02:33 PM #13
05-21-2010, 06:28 PM #14
Tell them to keep a fire extinguisher handy. After you spray down the fire, you can use the extinguisher to break the window and climb out.
Seriously, was the window large enough to swap out for an operable that would meet the dimensions? Probably over two thirds of the houses I do have windows that don't qualify for the current opening and sill height.
05-21-2010, 07:48 PM #15
05-21-2010, 09:48 PM #16
I require the Realtor to provide me with the MRIS Property Listing. The listing says how many bedrooms the house has. If one of the rooms considered a bedroom does NOT meet the requirements, I point that out to the buyer's agent and the buyer. I also tell the buyers why certain rooms can not be considered bedrooms (assuming there are rooms that may be converted to bedrooms) and explain the safety issues relative to those rooms. But people will be people and will do what they want regardless of the potential consequences. All one can do is advise!
05-22-2010, 12:58 AM #17
05-24-2010, 01:24 PM #18
i find your views and interpretations quite entertaining and your thinking outside of the box and the constraints of a jurisdictional inspector fascinating! when and if i grow up and shred the chains (codes) that bind me ,maybe i can get a guest appearance on the marc and john show?
