Thread: Laundry Ventilation
08-16-2010, 10:00 PM #1
Laundry Ventilation
Dumb question-
Is ventilation required in an enclosed laundry room with a gas dryer?
Either a window or mechanical vent to the exterior ( Iknow the gas dryer must be vented to the outside).
Thanks,
Mike
08-17-2010, 03:37 AM #2
Re: Laundry Ventilation
SEE:
http://www.inspectionnews.net/home_i...dry#post110921
and is it a room, closet, or area, see also:
http://www.inspectionnews.net/home_i...dry#post112135
Air-to-Air exchanger can service this purpose.
Ventillation for occupied ROOM in addition to needed combustion air AND Make-up air required by the appliance(s).
HTH.
08-17-2010, 06:44 AM #3
2006 IRC, Section 2407 addresses this. Code, tables, drawings, etc. should have everything you need.
08-17-2010, 06:57 AM #4
M.K.,
"Mike Inpsector" lists location as "California", hence the two post links to posts complete with California Code links imbedded, local definitions, and location specific applications.
08-17-2010, 07:09 AM #5
Ah, yes I see that now. Young grasshopper must learn from aged scholar to look around bush for bird before looking somewhere else.
08-17-2010, 07:18 AM #6
