Results 66 to 69 of 69
Thread: Mirrored Walls Above Tub
10-05-2010, 09:47 AM #66
Re: Mirrored Walls Above Tub
When they use the information I have provided, and as I laid the code out and explained what the code says and how it says it ... they will be correct.
You and H. G. are only reading the part of the code you want to apply, not the entire code as the code is written.
I believe most others understand it, so I will leave this to you and H. G. to continue your cause.
For all others, I believe they can, and will, read and understand what the code says.
10-05-2010, 10:14 AM #67
10-05-2010, 02:30 PM #68
Those statements are false to YOU, and THAT is what everyone needs to know.
Ken,
You can continue with your uninformed rant of what YOU THINK to be correct ... will rest with assurance that THE OTHERS know how to read the code and that they understand what has been posted by me.
Rant away, I'm outta here as it is obvious that you will not, cannot, admit when you are wrong, even when the code is posted word-by-word and explained to you.
Hopefully no others will fall into your misguided trap, regardless how many times you come back here and incorrectly insist that you are correct.
10-05-2010, 04:23 PM #69
They aren't just false to me, they're false by what's written in the code and common sense.
I'll freely admit that I've made some incorrect statements on the forum. But, every time I have I've apologized and admitted my mistake. This is not one of those times.
