Results 1 to 22 of 22
Thread: Inspection recommendations
11-20-2010, 11:00 AM #1
I am gratefully for the wealth of information provided on this forum and others. I am asking for the help of anyone who cares! I appreciate time you would give to a newbie. I hope I have "payed it forward" on other forums providing medical and home theater knowledge and you will be so kind to help me.
We have a very impressive detailed home inspection but not sure what to do with many things. Can you please help? Here are some items
1. Electrical wire oxidation, wire double taps, overheated wiring and breakers. Plan to have electrician check out the house. How far should I go with the whole chinese drywall business. House is in houston and was remodeled in 2005.
2. No palm bracing, H clips and hip rafters not braced per standards today. Some sagging of roof at front attic.
3. Living room ceiling is sagging and small area of floor slopping in up stairs. The remodeling company is coming to check it out. Should I hire a structural engineer?
4. Living room ceiling water stain. How do you check if or where the leak is without ripping out the entire sheetrock?
5. No damper stop on flue damper. No log lighter pipe.
6. No gas sediment traps. I understand the concept after doing some reading but how crucial is this?
Again I really appreciate any help. Besides the above the house is amazing and we would love to not have to walk away.
11-20-2010, 11:38 AM #2
Re: Inspection recommendations
Me first? Others will chime in. We need to know the age of the house, it sounds to be older. Older than 50 years, you could be dealing with plaster on the ceiling and walls.
Yes, the electrical panel sounds like it needs repair. Be prepared to change up to a new distribution panel and possibly new service. Could you give us the size, amperage of the service and the home square footage?
Re: the water stain, Older homes have stains, but the leak may have been fixed. An inspector can use a moisture meter to see if the stain is an active leak. Infrared imagery can tell you a lot about what's behind the surface. Somebody here knows an inspector you can call.
We need pictures of the sagging roof to comment further. Ditto the sagging floor. What's under it?
Look for corrosion on copper wiring at outlets in the remodeled areas of the home. That is the simplified answer to your Chinese drywall question.
Your gas log needs to be checked out by a gas heating technician and repairs are needed for safety. New home and you want it to be safe? Replace whatever is there with a modern cost-efficient and safer unit. You will save $$$ and be safer.
The sediment traps keep your jets clean. Dirty jets are bad.
11-20-2010, 11:52 AM #3
The house was built in 1991 but completely remodeled in 2005 to the studs for the entire house. A second floor theater addition was added over an outdoor patio.
The house is 4100 square feet with pool, spa, outdoor kitchen and a/c garage it that helps with electrical. There are two Square D brand 200 amp panels in the garage. A GE 50 amp subpanel is in the new theater. A Cutler Hammer 60 amp sub panel is located in the exterior equipment bay.
I can get pictures of the sagging ceiling but it may not be evident in photos. The ceiling is first floor living room. The sagging floor is in a second floor spare bedroom above the kitchen. Kitchen and living room are adjacent, really one large room.
The inspector did use infrared camera but only noted "Water staining was observed at living room. The cause for the staining should be determined and repairs undertaken, if necessary, to prevent damage" No talk about active or not.
No gas logs but it is plumbed. I believe it to be a convert wood burning chimney. I will get this checked out.
The oxidation is only at the electrical panels not the outlets in the home. Not sure if that helps.
11-20-2010, 02:05 PM #4
That helps a great deal. The electrical will need repair for corrosion but it appears that the supply will be adequate and the panel will likely be OK after the repairs are made.
All still a wild guess without pics.
If there is no gas log, then I don't know what the gas and damper comments were about. This is a general statement. Gas sediment traps are required on any appliance which operates independently without human supervision, such as furnace or water heater. Fireplace, clothes dryer, no sediment trap required.
Re; Chinese drywall - I would recommend removing outlet covers throughout the house so that the copper wire ends can be examined for tarnish. Sometimes the drywall labeling is visible in the attic, but they may not have stripped the old ceiling drywall off, so that's not going to be conclusive. There was plenty of the bad drywall around in your area in '05, AFAIK.
Your inspector should give you more info regarding the water stain. He must have some idea from his IR training.
Sagging ceiling, big renovations, somebody may have removed a wall that was supporting the ceiling. Look for plans and permits.
11-20-2010, 02:09 PM #5
Does the home have Chinese drywall? If it does then I would walk away.
Electrical problems need to be corrected.
I have never head of "palm" bracing? "H" clips are not required. What or how are the hip rafters not braced properly? A "hip" rafter is usually self supporting if built properly.2. No palm bracing, H clips and hip rafters not braced per standards today. Some sagging of roof at front attic.
Was the work permitted when they did the remodel?3. Living room ceiling is sagging and small area of floor slopping in up stairs. The remodeling company is coming to check it out. Should I hire a structural engineer?
Best way is to look from the attic. Next best is from the roof itself.4. Living room ceiling water stain. How do you check if or where the leak is without ripping out the entire sheetrock?
Not a big deal. Damper locks cost $1. So does it have gas in the fireplace and just no lighter pipe? IF so and if you want it, get a plumber to install it for under $100.5. No damper stop on flue damper. No log lighter pipe.
Call the gas company and see if they are needed in your area. Some areas have dirty gas and they need them, other have very clean gas and do not need them. To be on the safe side they should be installed...6. No gas sediment traps. I understand the concept after doing some reading but how crucial is this?
Love can be blinding....!Again I really appreciate any help. Besides the above the house is amazing and we would love to not have to walk away.
11-20-2010, 04:44 PM #6
The building contractor, who is supposedly of good quality, say they can provide documentation regarding the remodel from the manufacture confirming there is no chinese drywall. So that is good. Inspector did not check the outlets for oxidation. Electrician will be coming out. Hopefully it wont be hard to repair/replace oxidized wires and find the cause of overheated breakers and a few outlets. Thoughts?
I am told the work was permitted. It was a major renovation in a community that is pretty nitpicky. I guess I could call city and find out for sure.
Regarding sagging ceiling and sloping floor; no walls were removed. We have the pre-construction pictures to confirm. Maybe just settling from good old Texas soil! Should we get a structural engineer to confirm. The foundation checked out okay minus some slacking.
11-20-2010, 05:22 PM #7
A comprehensive evaluation for function and safety by a qualified, state licensed electrician. 1991/with signs of overheating circuits - not good!
How far should I go with the whole chinese drywall business. House is in houston and was remodeled in 2005. If Chinese drywall is prevalent in this area - or suspected in this tract - invasive testing is prudent!
A. Palm bracing is not a typical construction phrase - clarify.
I assume your roof framing is truss.
B. H clips not required on 5/8's or better.
A. You definitely want to know why the ceiling is sagging.
With a written estimate for repair. having been a framer for 30 years
I don't like the sound of that condition. Not because it means your house
is falling down but because it sounds costly. I expect ceiling joist crowned
upside down.
B. No engineer yet - first check out what the remodeler has to say and bring
your own contractor buddy along.
A. The seller is required to disclose past history.
B. Is there a bathroom above the stain.
A. $4. dollars at your home depot.
A. An absolute must at all required gas appliances.
Again I really appreciate any help. Besides the above the house is amazing and we would love to not have to walk away.[/quote]
mf
Matt Faust
Real Estate Inspector
11-20-2010, 06:15 PM #8
IMHO,
A house less than 15 years old gutted to the studs was done for a reason not cosmetic.
* fire
** Water damage
*** WDO
**** Combination of the above.
Time to Check the Insurance CLUE Report.
11-20-2010, 06:16 PM #9
Must be a CA thing.... not the case per the IRC.2. No palm bracing, H clips and hip rafters not braced per standards today. Some sagging of roof at front attic.
11-20-2010, 06:35 PM #10
11-20-2010, 06:44 PM #11
11-21-2010, 05:12 PM #12
11-21-2010, 06:12 PM #13
When was this work completed in 2005?
2005 was a rough year to be doing voluntary remodeling/construction. Not only was the supply chain disrupted after massive katrina losses...and a horrific 04 season east; the labor forces were disrupted too.
2005 "Rita" did some damage to your area. There were some flooding issues IIRC - near a dam site. Then there was Ike in 08 IIRC.
Timing, as they say, could be everything.
Ask your insurance agent for the CLUE report for the property.
11-22-2010, 09:46 AM #14
11-23-2010, 08:43 AM #15
11-23-2010, 02:52 PM #16
All I can say is the clue is normal. The seller has more money than he knows what to do with. Most people don't put subzero fridges in the gameroom! He wanted to make the house top notch, including complete home crestron sytem, venetian plaster, steam shower, custom cabinetry, etc, etc. We have picture of prior to remodel, during and after. I have no reason to belive something untoward happened to the house.
Why is it so unusual to remodel a house? You would have a tough time selling a house 20 years old with updating in the area it is in!
11-23-2010, 02:58 PM #17
11-23-2010, 03:02 PM #18
11-23-2010, 03:59 PM #19
11-23-2010, 04:06 PM #20
We tend to be a suspicious lot by nature, usually justifiably so. You asked for opinions. If everything you were told by the seller is true and the inspector on site had no concerns (assuming you used a experienced and competent inspector) then go for it.
By the way from your dates the house was only 14 years old when there was a total gut, not 20 years old. That is an unusual situation but not unheard of in high end areas.
My one concern would be oxidation on the wires... and the cause. 2005 is prime time for Chinese drywall and I would look at this VERY CLOSELY. Don't take the contractors or sellers word. Find out the cause for the corrosion and get a second opinion about the drywall from an independent source. If there is or ever was tainted drywall present in the house then every single piece of metal in the home is subject to damage and another complete gut not only of the drywall but electrical, plumbing, hvac, etc. is on the horizon.
11-23-2010, 06:29 PM #21
Thanks. Any idea where I can find someone in Texas/Houston that specializes or has experience in Chinese drywall? I talked to my inspector and he just said it could be a cause but couldn't tell for sure and didn't know of who to get to do a more thorough inspection.
11-23-2010, 06:54 PM #22
Chinese Drywall Complaint Center
