Results 1 to 12 of 12
    Aug 2010
    BC Canada
    Default what are the 2 blocks on ceiling?
    I found these 2 blocks on ceiling when I inspected a 1981 built house. I do not know what that is. Anybody can help? Thanks
    Default Re: what are the 2 blocks on ceiling?
    What did you see in the attic over that area?
    I would not put forth a guess as to what it might be without knowing that first, and if there is nothing above those, then maybe not even then.
    Having said that ... those could be from an owner who had some art sculpture hanging from them, or ... who knows?
    Aug 2010
    BC Canada
    They are on the basement floor living room. You are right, Jerry. Hard to say it.
    James Duffin's Avatar
    James Duffin Guest
    Is there bathrooms above the area where the boxes are?
    Jun 2010
    Vancouver
    this is where you ask the realitor to ask the owner what they are, as opening them up is not acceptable. could they have been part of a old set of stairs or structural bracing that they didn't know how to deal with?
    May 2009
    Mn
    Boxed in plumbing or duct work ?
    Mar 2008
    Charlotte NC
    Quote Originally Posted by Peter Louis View Post
    Electro magnets, designed to pull all that fishing tackle out of lips, noses, wherever!
    Jun 2010
    Rochester
    Looks like a bulkhead for the heat/air duct to cross over the floor joist. Is that a heat vent in between them?
    Aug 2009
    Michigan
    Quote Originally Posted by Mike Moser View Post
    My thoughts exactly...They certainly aren't eye appealing, so I wouldn't guess they were done for any other purpose.
    Randy Gordon, construction
    Aug 2010
    BC Canada
    Quote Originally Posted by Michael Bupp View Post
    exactly
    Just a comment - I would describe them as 'boxes' as in hollow containers or covers, rather than 'blocks', which imply something solid like a block of wood.
    Covers over heat ducts are the best guess. They could be made less ugly by building false beams around them.
    It is what they use to tie up the folks from Wisconsin to knock some sense into them......oops.....wrong forum!
