Thread: cracking in between window panes
04-25-2011, 04:18 PM #1
On an inspection today, I noticed that the area between the two insulated panes had cracking of its paint. It was mainly on the bottom and a bit on the sides. The house is only 7 years old making the windows also about 7 years old. I wondered if anyone knew if this is just an aesthetic thing or is this something that may cause a problem later. I didn't note any fogging or troubles with the windows. I suspect it may just be UV damage, but thought I'd ask the experts.
04-25-2011, 05:13 PM #2
Re: cracking in between window panes
Is that paint? Looks like those might be vinyl frames.
04-25-2011, 05:27 PM #3
04-25-2011, 07:00 PM #4
IMO, it looks like the spacer in between the panes of glass is failing or just a bad design. If all is fine at time of Inspection, report it as such, but maybe mention the issue in report as a discretionary issue and to be monitored.
