Results 1 to 13 of 13
06-26-2011, 09:58 AM #1
Suspended ceiling grid with fiberglass inulation on top
Is it permissible to install fiberglass batts on top of a ceiling grid for a thermal barrier?
This particular installation is an attached garage that originally was open from the floor to the roof deck.
It has been converted to a living space.
Installed a ceiling grid at the cross bracing, put some fiberglass on it and called it a finished ceiling.
06-26-2011, 10:35 AM #2
Re: Suspended ceiling grid with fiberglass inulation on top
When you say grid are you referring to a drop ceiling? Such a ceiling would not be a proper barrier from the living area above regardless of what it's called. To specifically answer your question and not consider any side issues - I see no problem with insulation batts on the grid ceiling.
06-26-2011, 10:54 AM #3
06-26-2011, 06:26 PM #4
There's no vapor barrier. Even if they use paper-backed batts, it wouldn't be a sealed barrier.
06-27-2011, 05:34 AM #5
Very common in commercial applications where there are offices built within a warehouse type building.
All the best,
Bruce Low
Bottom Line Home Inspection
The Bottom Line - Through an Engineer's Eyes
06-27-2011, 05:39 AM #6
06-27-2011, 10:45 AM #7
06-27-2011, 12:59 PM #8
not acceptable in california.
06-27-2011, 01:33 PM #9
If this is an inspection, you may want to direct your client to the AHJ for permit information. There is a good chance there was no permit pulled to convert the garage, and there are issues too numerous to mention with it.
06-27-2011, 10:57 PM #10
Hi Jon, I think what people are thinking is that it is still being used as a garage where exhaust from cars/vehicles still can get it. this is an issue if that is the case, however if there is no exhast or fumes to worry about treat it as any normal shelter for insulating purposes and venting issues. the area you are talking about is basically an attic of sorts.
cheers
06-28-2011, 03:24 AM #11
Normally when you have paper-backed insulation on the top of a suspended ceiling the ceiling is fire-rated since the paper can not be left exposed.
06-28-2011, 06:59 AM #12
Re: Suspended ceiling grid with fiberglass insulation on top
06-28-2011, 10:45 AM #13
As far as an issue laying on the panels there is not a issue except contact with non-rated can lights, etc. that I am aware of, hard to make a good barrier though but better then nothing.
