Results 1 to 9 of 9
Thread: CO or fire detector?
08-11-2011, 08:46 AM #1
Can anyone identify whether this device mounted on the ceiling in the kitchen area of a home built in the '90's is a CO sensor or part of a fire detection system?
08-11-2011, 11:06 AM #2
Re: CO or fire detector?
That looks like a Heat detector.
If so, then it is a component of an alarm system, likely to also contain smoke detectors.
Heat detectors are most often 3"-6" round.
Most heat detectors are not testable, and cannot be reset (one time use only).
I cannot tell from the picture, but it should indicate if it is 135 degree (for use in the living areas and garage/ storage), or 195 degree (for use in attics).
08-11-2011, 06:09 PM #3
08-11-2011, 06:17 PM #4
Something like thatDon't heat detectors tell you when it is too late to run, that it is time to just curl up in a corner and kiss your butt goodbye?
An alarm company wanted me to install only a heat detector in a house for thier customer, I told them "You'll have four dead people before it goes off".
Anyhow, heat detectors are useful where you should not use a smoke detector, ie. attic, garage, kitchen, very dusty areas.
08-12-2011, 08:28 AM #5
[FONT='Arial','sans-serif']This is a Replaceable-element fixed-temperature heat detector.
[FONT='Arial','sans-serif'] [/FONT]
[FONT='Arial','sans-serif']I’ve read a complaint litigated during the 1980s on how heat detectors were pushed onto consumers over smoke detectors. Seems they lost out.[/FONT]
[FONT='Arial','sans-serif']Recommendation: Ensure that the home has the minimum required smoke detectors in the home and do not rely solely on heat detectors.[/FONT]
[FONT='Arial','sans-serif'](1) In nearly all residential fires, life endangering conditions will[/FONT]
[FONT='Arial','sans-serif']occur prior to the activation of respondent' s heat detectors. Such heat[/FONT]
[FONT='Arial','sans-serif']detectors, therefore, do not provide sufficient warning to occupants in the event of fire.[/FONT]
[FONT='Arial','sans-serif'](2) Respondent's fire alarm systems combining heat detectors and[/FONT]
[FONT='Arial','sans-serif']smoke detectors do not provide significantly greater fire warning[/FONT]
[FONT='Arial','sans-serif']protection for occupants than smoke detectors alone.[/FONT]
[FONT='Arial','sans-serif']FIGGIE INTERNATIONAL, INC.[/FONT]
[FONT='Arial','sans-serif']FINAL ORDER IN REGARD TO ALLEGED VIOLATION OF SEC. 5 OF THE[/FONT]
[FONT='Arial','sans-serif']FEDERAL TRADE COMMISSION ACT[/FONT]
[FONT='Arial','sans-serif']Docket 9166. Complaint, May 1983-Final Order, April , 1986[/FONT]
[/FONT]
08-12-2011, 05:58 PM #6
Thank you very much, Rick.
08-12-2011, 05:59 PM #7
Thank you very much, Henrey
08-15-2011, 03:00 PM #8
If it is a heat detector, it should be connected to a bell or horn to alert the occupants inside the residence in the event of an activation. You should be able to find a fire alarm control panel or a notification device somewhere in the house. If not, it may not be hooked up anymore. Some heat detectors are restorable, some are not. It's hard to tell with this device, I haven't seen one like this before. It looks old. Were you able to find any markings on it at all?
08-16-2011, 07:44 AM #9
Thanks for your response. There were not any markings on the device however, we were able to confirm that it is a heat sensor connected to an old alarm system.
