Thread: What are these?
    Aug 2010
    BC Canada
    Default What are these?
    What is the pic1 cover plate with 1" hole beside receptacles in living & den about 5' high?
    Is pic 2 white plastic the security alarm buzzer? or a humidistat. I cannnot turn off the hall way bath fan, cannot located the timer or humidistat.
    Inspection Referral SOC
    Default Re: What are these?
    Quote Originally Posted by Peter Louis View Post
    Pic 1 Shows a Mistake ( Something was or should have been installed or a hole was drilled by mistake. )
    Pic 2 is a Low Voltage Transformer My Guess is for the Alarm System.
    Photo #1
    Looks like a cover plate for round modular phone outlet, with out the outlet inside.
    Sometimes are used by DIY for cable runs.
    Photo #2
    The cabinet is to an alarm system. Alarm siren is above the alarm cabinet.
    The tan device with zip tie is likely the transformer (power supply) for the alarm system.
    I think the other device is a doorbell/ buzzer transformer.
    Mar 2011
    Sparks,NV
    The single hole plate looks like the cover plate for a singe receptacle. I've seen them used for speaker or cat 5 wires before. The white box looks like the alarm speaker.
    Nevada IOS#1730
    Nevada Energy Auditor #30
    775-342-4767 www.homecsi.com
    Garry Blankenship's Avatar
    Garry Blankenship Guest
    My guess/s / final answer is Pic1 = Low volatage cable outlet, ( cable, data, communication ), on the left and a duplex receptacle on the right w/ your tester still in it. Pic 2 = Left is a F/A or security system enclosure and right is a door bell xfmr.
    Rick, Robert and Garry win on #1. It is 5' high up the wall in the living room with a duplex receptacle below. J- box for the TV cable, TV not installed yet.
    Ditto on the alarm box and buzzer.
    Aug 2010
    BC Canada
    I'm Guessing this is the same 5 year old house in your other post.
    * 5 years and No TV installed yet?
    ** Did he miss his Monday from 1 to 4:30 appointment ?
