Results 1 to 16 of 16
Thread: window bars at bathtub
05-17-2012, 11:20 AM #1
I've never seen this before - non-safety glazing next to the bathtub, with bars.
Assuming the bars are strong enough, I guess this is ok, eh?
05-17-2012, 12:05 PM #2
Re: window bars at bathtub
I would say, Not.
05-17-2012, 12:11 PM #3
05-17-2012, 12:35 PM #4
As you mentioned this is a safety glass area. What's shown in the photo, is in my opinion
still unsafe. Someone who slips and falls may not go all the way out the window. But could still be swimming with shards.
05-17-2012, 12:45 PM #5
05-17-2012, 01:26 PM #6
05-17-2012, 01:52 PM #7
05-17-2012, 01:54 PM #8
Try this one.
2003 IRC
R308.4 Hazardous locations. The following shall be considered specific hazardous locations for the purposes of tempered glazing:
- 5. Glazing in doors and enclosures for hot tubs, whirlpools, saunas, steam rooms, bathtubs and showers. Glazing in any part of a building wall enclosing these compartments where the bottom exposed edge of the glazing is less than 60 inches (1524 mm) measured vertically above any standing or walking surface.
05-17-2012, 02:03 PM #9
05-17-2012, 02:29 PM #10
No problem. I keep the safetyglass.pdf file on my phone, along with a bunch of others, in case there is a question. It has come in handy several times. Also need to credit the source for the file
http://www.arnonebuilding.com/saftyglass.pdf
Several good examples of issues that come up on decks, stairs, railings and the safety glazing are to be found there.
05-17-2012, 03:17 PM #11
John,
There is a list of exemptions. 1 of them has to do with the photo you presented. There are parameters which need to be met in order to allow the exemption. I don't think you could verify them if you were not the installer. Bar supports 50 # psf. Fasteners are equal to the task. If the fasteners go through the jamb is there solid material through to the framing. I'm new to this. It appears to be an obvious safety concern to me. Are we supposed to only act or give our thoughts on code compliance.
I do not mean that last question in a smart alec tone.
05-17-2012, 04:08 PM #12
There are exemptions from having to have safety glass in *some* specific locations, and one of the exemptions is to have a permanent barrier between the glazing and the person, but ... but there are *NO* exemptions regarding that location at tubs and showers.
05-17-2012, 04:16 PM #13
Looking in 2006 IRC and I can't find an exception to 308.4 item 5, which contains the rule concerning the glazing at tubs and showers. Different version of IRC or am I just missing it? The exception you listed is for 308.4 items 7 and 10. Item 7 actually excludes the tubs & showers from the exception, and item 10 is for stairways ramps and walking surfaces
05-17-2012, 05:07 PM #14
05-17-2012, 07:19 PM #15
Thanks Mr. Peck
05-17-2012, 07:32 PM #16
