Thread: UBC vs IRC
07-01-2012, 01:04 PM #1
UBC vs IRC
Prior to the inception of the IRC in 2000, is it likely that jurisdictions used the UBC prior to 2000? I'm trying to track down code requirements for Howard County Maryland with regard to window sill height relative to egress requirements.
I did find the following document but I'm not totally sure the jurisdiction followed the UBC in 1982.
The issue is a room in a basement being called a bedroom with a 54" high window sill (built in 1982).
http://www.dli.mn.gov/ccld/PDF/sbc_EgressDates.pdf
07-01-2012, 03:28 PM #2
Re: UBC vs IRC
John, does it really matter what the code was? I don't know what MD requires in reports but the EEO requirements make the height a safety hazard in a sleeping area. I report that as an "Advisory". Can't make'm fix it but your client should know what and why it is and they can make"future improvements".
Stu, Fredericksburg VA
07-01-2012, 06:32 PM #3
Re: UBC vs IRC
07-01-2012, 06:44 PM #4
Re: UBC vs IRC
Only when I KNOW when the building permit was issued.and only if I have access to the codes in question. But otherwise no.
I don't feel it necessary to back up my position with a code reference. I made my evaluation and stated it, wrote it, and signed the report. If someone wants a code to back it up, then I'll tell them to find it. When stated in terms of safety and fire hazards, I've never had recommendations challenged by anyone wanting a code reference. That includes some pretty tough old bird real estate agents. When it makes sense to my client, then who in their right mind would challenge that other than a seller or listing agent and if they do they are putting themselves into a hole and starting to cover it up.
07-01-2012, 06:47 PM #5
Re: UBC vs IRC
Well Stuart, it seems like you and I basically agree.
07-01-2012, 07:11 PM #6
07-01-2012, 07:58 PM #7
Re: UBC vs IRC
