Results 1 to 10 of 10
Thread: closets
    Dec 2012
    ut
    Default closets
    I can't find anywhere in the irc where it specifically talks about closet dimensions. does anyone have information on required closet heights and dimensions?
    thanks
    Atlanta, Georgia
    Default Re: closets
    Closets are not required by IRC therefore there is no discussion about min or max sizes. There are limitiations or specfications for things like distances to light fixtures, ventilation if being used for mechanical equipment, etc. but no min or max size.
    Supposed you wanted to store your collection of fishing poles. Only needs to be about 6 inches deep. Add some shelves and it becomes a giant medicine cabinet. Remove the door and it becomes an alcove to display art. Not very useful for hanging clothes but not all closets are for hanging clothes.
    Not habitable space so IRC does not really care.
    Sep 2007
    Fredericksburg, VA
    Default Re: closets
    In agreement with Bruce I add that closets are a MLS- realtor point of concern not the IRC or home inspectors
    Stu, Fredericksburg VA
    Dec 2012
    ut
    Default Re: closets
    thanks. that would explain why i could not find info on them
    Dec 2007
    Holladay, UT
    Default Re: closets
    I thought each bedroom had to have a closet to be considered a bedroom? If that is true you could make it any size to meet the requirement? Not arguing just trying to understand.
    I'm going to answer my own post again. I really should look this stuff up and then reply to thread. What I found is that the closet is not a code requirement but is related to livability:
    What Makes a Room a Bedroom? - Bob Vila
    http://acloserlookslc.com/
    Default Re: closets
    I thought each bedroom had to have a closet to be considered a bedroom?...
    I think that is the rule used by appraisers and MLS folks.
    I guess it is similar to the conditioned space connections between rooms to be considered part of the same structure (e.g., your 2000sqft home plus 500sqft bonus room over garage can't be sold as a 2500sqft home unless those two are connected via conditioned space)...
    Aug 2012
    Rock Hill S.C.
    Default Re: closets
    A lot of old houses had no closets when built, you had an armoire. At my grandmas house they had a "store bought one" in their room, the other bedrooms had homemade ones.
    May 2009
    Connecticut
    Default Re: closets
    Ryan,
    NEC 410.8 Luminaires (Fixtures) in Clothes Closets contains language describing clearances of fixtures within closets. The IRC E3903.11 reflects the same language.
    Default Re: closets
    Quote Originally Posted by Ted Cierocki View Post
    Ryan,
    So if a closet is ( not required ) present and has lighting in it then these requirements must be meet.
    Atlanta, Georgia
    Default Re: closets
    Quote Originally Posted by Chris McIntyre View Post
    At one point in the US, homes were taxed based on the number of rooms. Closets were considered a room, therefore a higher tax rate. Many Victorian homes dont have closets. This is one potential answer to a lack of closets.
    Secondly, people only had one set of clothing. Two at most. You are wearing one set and washing the other. Who needs a closet when you only have one set of clothing? Only in the last hundred years have people routinely had more than 2 sets of clothing.
