Results 1 to 2 of 2
Thread: Fireseparation
    Clay White's Avatar
    Clay White Guest
    Default Fireseparation
    Jonathan Cartwright's Avatar
    Jonathan Cartwright Guest
    Default Re: Fireseparation
    Quote Originally Posted by Clay White View Post
    See picture........Does the wall between the garage and laundry room need to be of fire separated material with no gaps/holes?
    FYI: The door from the kitchen to laundry room is a hollow door.
    The door from garage to laundry room is solid.
    I would call this in my report. The solid core door between the garage and laundry implies a fire separation and the surrounding walls should be a proper fire separation too. If the laundry were added into the garage later and an unbroken fire rated wall/door were in place between the garage/laundry and the kitchen then I would not think that the laundry room would itself need to be fire rated.
