Results 1 to 11 of 11
		Thread: Moisture Damage on Interior Wall
	03-12-2014, 03:59 AM #1 Moisture Damage on Interior Wall Moisture Damage on Interior WallThe house has a stucco over brick exterior wall surface and plaster interior walls. The exterior stucco was fine with no cracks and no gaps on the exterior window ledge. The AC condenser unit was located about 1.5-2 feet away from the exterior wall surface where this appears. There are no plumbing lines in this area. But this small area of interior wall surface has the moisture damage and and elevated moisture level. My only guess is that the exterior wall surface in this spot has little air flow and no direct sunlight and as a result, the area remains cool and damp and moisture has migrated through the wall.
 Thoughts?
 (pics deleted)
 Last edited by Nick Ostrowski; 03-12-2014 at 05:21 AM. "It takes a big man to cry. It takes an even bigger man to laugh at that man". - Jack Handey
	03-12-2014, 04:10 AM #2 Re: Moisture Damage on Interior Wall Re: Moisture Damage on Interior WallNo or little insulation, likely no vapour barrier (old house) condensation occurring.
	03-12-2014, 04:33 AM #3 Re: Moisture Damage on Interior Wall Re: Moisture Damage on Interior WallNick,
 Is that a chair rail or a window sill in the photo?
	03-12-2014, 05:01 AM #4 Re: Moisture Damage on Interior Wall Re: Moisture Damage on Interior WallAlso Nick what is the age of the house? Also do you know if its balloon framed?
	03-12-2014, 05:16 AM #5 Re: Moisture Damage on Interior Wall
		"It takes a big man to cry. It takes an even bigger man to laugh at that man". - Jack Handey Re: Moisture Damage on Interior Wall
	03-12-2014, 05:17 AM #6 Re: Moisture Damage on Interior Wall Re: Moisture Damage on Interior Wall
	03-12-2014, 05:19 AM #7 Re: Moisture Damage on Interior Wall Re: Moisture Damage on Interior WallI'm just going to delete them. Posting pics here has become a pain in multiple ways. Pics are too big or pic file name shows.
 Last edited by Nick Ostrowski; 03-12-2014 at 05:34 AM. "It takes a big man to cry. It takes an even bigger man to laugh at that man". - Jack Handey
	03-12-2014, 05:39 AM #8 Re: Moisture Damage on Interior Wall Re: Moisture Damage on Interior WallLime based old plaster, painted over with inappropriate non breathable paint, lime based plaster has to breathe, paint has trapped moisture.
	03-12-2014, 06:09 AM #9 Re: Moisture Damage on Interior Wall Re: Moisture Damage on Interior WallLeaking around the window would be my SWAG.
 I never have problems posting pictures. I just use the upload feature and they post. I think most of my image file sizes are all in the 100kb to 200kb range, I have my camera set on the lowest resolution or Email setting.
	03-12-2014, 09:49 AM #10 Re: Moisture Damage on Interior Wall Re: Moisture Damage on Interior Wall
	03-12-2014, 10:15 AM #11 Re: Moisture Damage on Interior Wall Re: Moisture Damage on Interior WallThe exterior frame and sill looked tight with no visible gaps or openings. Who knows.
