Results 1 to 3 of 3
    Mar 2010
    Ocala Florida
    Default Thermo pane window seal gasket bulging out
    Need help with this and how to report, is it cosmetic, is it a sign of impending seal failure, what causes it and so on. Thanks
    Default Re: Thermo pane window seal gasket bulging out
    Report it as a defect.
    What likely caused it is swelling from heat by sunlight.
    Yes, that is a defective window. For some reason it is very common with half round windows like the one in the photo and also with long rectangular windows.
    When I find them I say something like this:
    "The ______ window has a swollen gasket/seal, this is an indication of a defective windows. The only cure is its replacement".
