Results 1 to 12 of 12
Thread: Safety Glazing
04-09-2007, 03:36 PM #1
Safety Glazing
Would you say this would qualify for safety glazing requirement?
The adventure continues... Jeff G
04-09-2007, 04:02 PM #2
04-09-2007, 04:33 PM #3
Re: Safety Glazing
Yes they need to be. Are you sure that they don't have safety glass in them?
They look like older Pella casement windows, safety glazing is an option that is very common. Pella sells the windows for each home based on a survey of the home. But then you never know what happens after the materials are on site!
04-09-2007, 04:35 PM #4
04-10-2007, 05:10 AM #5
Re: Safety Glazing
Thanx for the replies. Scott, I though they might be safety glazed but were not clearly marked as required. I looked for the etching on the glass. Built in 2002 I would have thought it was a no brainer. Thanx again! Jeff G
04-10-2007, 02:48 PM #6
Re: Safety Glazing
It is ironic that I have two inspections in two days with safety glass as an issue. This one had the tempered glass between the shower and whirlpool but the exterior frosted window was not. The builder came by about the time I was taking my picture to see if I had any problems. Since the buyer was there, I mentioned the safety glass missing from exterior window. He says the specification sheet called for it...I think maybe the cleaning lady removed the label before I got there. I just smiled and showed him the safety glazing marking etched into the glass between the shower and said it could not be on a removable label. I thought to myself nice try. He also didn't like my comment about no motor access for the whirlpool without tearing out the garage ceiling when a problem arises.
A different adventure everyday...Jeff G
04-26-2007, 11:29 AM #7
Re: Safety Glazing
I dont inspect alot of "manufactured" homes, and I understand that the HUD regulations and not local codes are followed. My question is this particular 1999 model had several windows within 12" of floor that met all the other rules for being tempered glass but were not. Do you guys call this as a defect or just note it to the buyers as a FYI.
04-26-2007, 01:47 PM #8
Re: Safety Glazing
Paul,
If if looks unsafe, and by all measures you are aware of - is 'unsafe', then by all means ... write it up, code or no code.
"Code" is only the minimum-crappiest-you-are-legally-allowed-to-build-something-starting-point.
"Code" is not 'good', code is "minimum", and code does not, cannot, address all conditions.
04-26-2007, 01:50 PM #9
Re: Safety Glazing
Jeff,
I just noticed something in your photo ...
http://www.inspectionnews.net/home_i...g-cooper31.jpg
(Brian, is there a way to show the photo link so it can be repeated and have the thumbnail show again, instead of just copying the link like I did above?)
Those impalement hooks.
Yikes! Right there at the end of the tub, when you slip and fall, forget the window, watch out for those impalement hooks!
04-26-2007, 09:57 PM #10
Re: Safety Glazing
Code or no code... it doesen't matter. If there is an obvious safety condition that the buyer needs to know about-- by all means identify that condition in the report as a possible safety issue.
Here is mine from today's inspection-- The return-air vent is positioned to where the opening end of the vent cover is right over the staircase on the upper level. Anyone changing the filter out has to be completly exposed over the railing.
While I do have my Master Parachute Wings, I certainly do not want to do a PLF from that height.
04-27-2007, 05:13 PM #11
Re: Safety Glazing
Good eye Jerry. The less experienced inspector like myself would have to look twice for that one. I guess I haven't seen as many horror shows with impaled victims. At least they are supplying the towels to clean up the mess.
A different view and lesson learned everyday...Jeff G
07-23-2007, 04:53 PM #12
Re: Safety Glazing
Today's pre-listing inspection; noticed that the lower sash to the left of the door was very loose in its track.
Seller said her husband - who had had a Parkinson's like disease - had fallen through it when she was out of the house.
Replacement is not safety-glazed.
