    Iron Mountain, MI
    Default Tub Surround Material
    Hi:
    Is this material suitable for wet location use? It's in a mobile home. It's hard to see from the pic, but the material is the same stuff you see on mobile home interior walls like bedrooms. I call it 1/4 board.
    Seller says it came with the mobile home so it must be ok.
    Default Re: Tub Surround Material
    Quote Originally Posted by Joe Arcaro View Post
    Hi:
    Your pic doesn't show much and your description is vague. Is it FRP board? Another product that I have seen in manufactured homes as well as homes built around here in the 1970s was a product that we refer to as "Marlite". This product is a hardboard (like Masonite) that has a thin vinyl coating. This certainly has a limited life span and often fails at seams and penetrations.
    Manufactured homes conform to HUD standards rather than local building codes which are generally prescriptive. As a result, many products that are not used in site-built homes are used in manufactured housing because of cost as well as their ability to withstand the movement caused by travel.
    Aug 2011
    Some of these products have a baked on paint finish. None of them hold up to regular wetting. You can still buy the stuff and you can still replace it in about a year of daily use.
    Mar 2012
    Lansdale, PA
    Manufactured home builders use a lot of sh.. (stuff) that is poor quality. It may be permitted, but if it is tempered hardboard based it will not last a long time.
Tags for this Thread
