Thread: Tub Surround Material
10-05-2015, 11:03 AM #1
Hi:
Is this material suitable for wet location use? It's in a mobile home. It's hard to see from the pic, but the material is the same stuff you see on mobile home interior walls like bedrooms. I call it 1/4 board.
Seller says it came with the mobile home so it must be ok.
10-05-2015, 04:15 PM #2
Re: Tub Surround Material
Your pic doesn't show much and your description is vague. Is it FRP board? Another product that I have seen in manufactured homes as well as homes built around here in the 1970s was a product that we refer to as "Marlite". This product is a hardboard (like Masonite) that has a thin vinyl coating. This certainly has a limited life span and often fails at seams and penetrations.
Manufactured homes conform to HUD standards rather than local building codes which are generally prescriptive. As a result, many products that are not used in site-built homes are used in manufactured housing because of cost as well as their ability to withstand the movement caused by travel.
10-05-2015, 05:17 PM #3
Some of these products have a baked on paint finish. None of them hold up to regular wetting. You can still buy the stuff and you can still replace it in about a year of daily use.
10-05-2015, 05:51 PM #4
Manufactured home builders use a lot of sh.. (stuff) that is poor quality. It may be permitted, but if it is tempered hardboard based it will not last a long time.
