Results 1 to 3 of 3
    Jan 2016
    Florida
    Default Door from interior to garage?
    Im assuming the Masonite Heritage Lincoln Park door would not be suitable as garage to house entrance door?
    http://www.masonite.com/pdf/catalogs...ush.pdf#page=1
    THe description of the interior doors we purchesed from that line is:
    30x80 Heritage Lincoln Park Model SHaker Design Interior Predrilled PreHung Solid Core Primed satin nickle
    How can i verify is the door is a 20min door or not?
    New Mexico
    Default Re: Door from interior to garage?
    I'd call the number on the brochure.
    The way to tell if the door is a 20-minute rated door is that the door will have a sticker on it which states it is a 20-minute rated door and who it was tested and listed by as being a 20-minute rated door.
    It will also come as a set with matching tested and listed jambs with matching hardware tested and listed for the 20-minute rated door assembly.
    The question is this: do you need a 20-minute rated door or are you just wanting a 20-minute rated door? There are other choices for the garage/house door permitted by most codes.
Tags for this Thread
