		Thread: Opinion on stair construction
	02-15-2008, 07:04 AM #1 Opinion on stair construction Opinion on stair constructionStairway at enclosed porch, feels solid when walked. Other than the rotting supports resting on the foundation ledge, what comments (if any) would viewers here make with regard to the non-standard construction?
	02-15-2008, 11:29 AM #2 Re: Opinion on stair construction Re: Opinion on stair constructionAwful skinny header plus should not the under side of that stair be rocked?
	02-15-2008, 12:13 PM #3 Re: Opinion on stair construction Re: Opinion on stair constructionI can't tell much from the photo, but the stringers look to be attached to a stick built "header" that is free to rotate away from the stringers as force is applied to the stringers. Looks like a recipe for catastrophic collapse when the nails pull out (if there are any.)
	02-16-2008, 12:09 PM #4 Re: Opinion on stair construction Re: Opinion on stair constructionHard to tell from just a pic, but Looks o.k. to me, as long as the fasteners are all there. Appears that the loads are all transferred to the floor or ledge below. It looks like the stringers/carrier are notched horizontally to be supported by the framing below. There is a carrier (middle stringer) in the middle which gives it even more support. I alway envision two guys and a refrigerator going up the stairs in situations like this. I am not sure how this could "rotate" since they are vertical loads. Worst case scenario, call out the rot at the ledge framing and make the comment: "Rot at base of stair support, recommend review of the stair system and repair as needed by a licensed contractor" That way you are covered.
	02-28-2008, 07:43 AM #5 Re: Opinion on stair construction Re: Opinion on stair construction- underside of stairs only needs to be covered with rock based on building occupancy classification or if area under stairs is used as a closet/storage area
 - untreated pine is supposed to be isolated from masonry foundation walls. Typically with wolmanized, some people use metal or rubber or ...
 - can't really comment on construction based on photo, except for flat header
