    Default Correct term for thermal window "gasket"
    What is the correct term for the rubber "gasket" which secures a thermal window pane into its frame?
    Also. come to think of it, is it "window pane" or "windowpane"?
    Default Re: Correct term for thermal window "gasket"
    It's window pane.
    The seal itself is just known as the air seal I believe. Maybe not.
    This is the component in question... of course, its the only one that's not labeled...
    Thermal pane sealing gasket [ works for me. ]
    Michael,
    Google "swiggle seal"
    No, its not a joke.
    Maybe thats what your looking for.
    Michael,
    No, its not a joke.
    Nope. That's a type of "insulating glass edge seal system" (from their web site).
    I would go with "weather seal" when referring to the outer "rubber "gasket" which secures a thermal window pane into its frame".
    There are "wet" seals and "dry" seals. "Dry" seals are those rubber one which are placed into the frame, while "wet" seals are "wet" applied sealant which is forced into the joint from a sealant (caulking type) gun, frequently those guns are pneumatically powered.
    New York
    Hi Guys,
    How has everyone been?
    It is called "glazing vinyl". It is a one piece "u" shaped strip that fits over the IGU (insulated glass unit) and the frame is pushed over it.
    When glazing flush glazing (store fronts) there are two separate strips. One gets installed into the frame prior to the glass lite or IGU being installed and the second gets installed after the lite is in place.
    If you ever need any, go to crlaurence.com
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
