Results 1 to 2 of 2
	08-11-2008, 08:58 AM #1 RFCI’s Recommended Work Practices for Removal of Resilient Floor Coverings () RFCI’s Recommended Work Practices for Removal of Resilient Floor Coverings ()Excellent reference material to which to direct clients and others with concerns about the removal of asbestos and other resilient floor coverings:
 "RFCI’s Recommended Work Practices for Removal of Resilient Floor Coverings are a defined set of instructions addressed to the task of removing all resilient floor covering structures."
 http://www.rfci.com/files/pdf/RFCIRecommended9-04.pdf
 Similar Threads:Last edited by Michael Thomas; 08-11-2008 at 09:10 AM.
	08-11-2008, 01:22 PM #2 Re: RFCI’s Recommended Work Practices for Removal of Resilient Floor Coverings () Re: RFCI’s Recommended Work Practices for Removal of Resilient Floor Coverings ()Good reference article. Thanks Michael. I run into this stuff all the time and recommend to my clients they do not remove but simply cover up if desired.
