05-22-2007, 05:40 AM
Storm window at interior
I came across an older house that had almost all new windows. One of the windows that was not new had a storm window at the interior wich prevented the window from opening.
This is a first for me and I was wondering how others would report it.
05-22-2007, 06:30 AM
Re: Storm window at interior
Definite egress issue.
Dave
05-22-2007, 07:20 AM
Egress issue IF it is the only window in a bedroom with only 1 door. Otherwise just a defective window operation.
05-22-2007, 07:22 AM
In need of repair, water entry is likely. The window does not open, so it is not functioning as intended.
Double whammy (technical term) if it is a window needed for egress from a bedroom.
Mr. Inspector.net, Inc.
Allen, Texas 75002
05-22-2007, 05:40 PM
Triple whammy ...
No natural ventilation as required either.
By the way, the 'two doors' does not solve the problem either - there needs to be two 'paths' (means of egress) in opposite directions. Two doors, opening into one hallway, going to the down stairs does not fulfill that requirement (option).
05-22-2007, 09:10 PM
Okay, my English as a third language issue is rearing its head again. 'splain to me please, the issue of a door to the outside in a sleeping area not sufficing for emergency egress. Thanks.
- Paul Fix
Reason: Bad wording
05-22-2007, 10:18 PM
'Cause that's not what was said.
This is what was said: "Egress issue IF it is the only window in a bedroom with only 1 door."
Nothing in there about "door" + "to" + "outdoors/outside".
Just "1 door". There could be 2 doors, neither leading directly to the outdoors.
Capice? (speelin'?)
05-22-2007, 10:38 PM
Capiche (sp?)
- Paul Fix
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Window brand needed |
Eric Laney |
Building Interior: Home Inspection and Commercial Inspection |
2 |
05-13-2007 07:11 AM |
| Interior or Exterior:Boulder |
Paul Kondzich |
10 |
05-10-2007 09:04 PM |
| outside my window |
John Arnold |
Tools and Equipment |
6 |
05-07-2007 06:19 AM |
| Leaking window |
william siegel |
Building Envelope: Home Inspection and Commercial Inspection |
5 |
04-10-2007 09:02 PM |
| Stains on the interior walls? |
Mike Huppi |
5 |
04-09-2007 06:46 PM |
