Re: slab cracks
Looks like bonding agent, just the opposite of what you would want to do over a crack.
Those LARGE cracks, all over like that, make me this the footing soil, not the slab soil, was not fully compacted as you are thinking. Pour the slab, build the walls, put the roof on ... all that wall and roof load now go down to the footing all around perimeter, compacting the soil under the footing ... and with NO LOAD on the middle of the slab, the middle of the slab stays put, with the edges being forced downward, it all cracks just like you are looking at.
From the sizes of the cracks I'm guess that all of the cracks are 'V' shaped, wider at the floor surface and narrower deep down in the cracks. Like if you were to take a just baked square cake and set it down over an upside down cup saucer in the middle of the cake - the cake will break apart as the outer edges drop down and the center stays up on the saucer.
Now the other question is, did the builder use WWM in the slab or fiber reinforced concrete? If he used WWM there is at least some reinforcement in the slab to somewhat keep it together, if fiber reinforced concrete, you are simply SOL.
