Re: Clarification needed
I'm assuming that "j-trusses" are jack trusses, as in those used in hips.
Typically you will have hip step down trusses (or hip trusses, depending on the truss designer, I usually see hip step down trusses), and hip jack trusses, these attach to the last step down truss (or to the hip trusses) and extend out to the wall.
Wind bracing would be diagonal bracing.
Have no idea what "pressure blocking" is.
