LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 06-08-2007, 02:41 PM
Wen Myrick Wen Myrick is offline
Window Testing? ? what the heck?
Today I was asked how I test dual pane windows/ how do I tell if they are bad or not....
I told the agent I LOOK at them, If they are fogged they fail.
She told me another Inspector TAPS on them
If they don't have a particular "sound"
He fails them.
What the heck is that all about?
Anyone heard of such a thing?
~Wen~
Old 06-08-2007, 03:24 PM
Victor DaGraca's Avatar
Victor DaGraca Victor DaGraca is offline
Re: Window Testing? ? what the heck?
I point my laser beam, infrared, non-contact thermometer at them and get a temperature variant reading of the ambient air temperature of the wall next to the window and the UV heat transfer properties of the dual glass, gas entrained window component. If the differential is less than two degrees, they pass.
Oh yeah.... I also look for "fogging"
www.Home2Spec.com
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Coming soon to a theatre near you . . . "The Window Whisperer".
Bruce Breedlove
www.avaloninspection.com
Old 06-08-2007, 03:41 PM
Rick Hurst's Avatar
Wen,
I've never heard of the tapping or the use of a laser gun.
I do know personally that if a window is suspect of a lost thermal seal you can hold a piece of ice against the glass panel for about a minute or two and then pull the ice away and you'll droplets in between the panes of glass.
If you see the droplets, it has a lost thermal seal.
Some of the window guys use dry ice for a quicker test I've seen.
Old 06-08-2007, 03:54 PM
Jack Feldmann's Avatar
Jack Feldmann Jack Feldmann is offline
If you "tap" with a ball peen hammer - the window will fail.
JF
  #6 (permalink)
Old 06-08-2007, 04:07 PM
Jerry McCarthy's Avatar
Every home inspector I know disclaims dual pane windows for the obvious reasons involved. Tapping on them is ridiculous and I'd rather see Jack's exam system used, the hammer test, failed under testing, to bad – so sorry!
We also installed it in the new CREIA SOPs; Part !!!, Limitations, Exceptions & Exclusions: #13 determining the integrity of hermetic seals at multi-pane glazing..
Construction Consultant
  #7 (permalink)
Old 06-08-2007, 04:21 PM
He fails them.
Weelllll, OF COURSE ... if they sound like the Bee Gees, you fail them, but if they sound like the Beatles, they pass.
Tap ... tap ... tap ... (listen closely) ... (sounds like 'We all live in a Yellow Submarine') ... Yep this one is okie dokie.
Home inspection
LinkBacks (?)
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/building-interior-home-inspection-commercial-inspection/1548-window-testing-what-heck.html
Posted By For Type Date
home inspection: Blogs, Photos, Videos and more on Technorati This thread Refback 06-08-2007 05:17 PM
Similar Threads
Mold and/or Radon testing.. Jason Welch Polls and Surveys 45 08-11-2008 07:28 PM
outside my window John Arnold Tools and Equipment 6 05-07-2007 05:19 AM
Testing GFCI Outlets Roger Kautz Electrical Systems: Home Inspection and Commercial Inspection 10 04-30-2007 06:30 AM
Radon Testing Equipment Brian E Kelly Tools and Equipment 2 04-25-2007 12:44 PM
Leaking window william siegel Building Envelope: Home Inspection and Commercial Inspection 5 04-10-2007 08:02 PM
vB.Sponsors
Ad Management by RedTyger
