Old 10-04-2009, 07:54 AM
Michael Carson's Avatar
Michael Carson Michael Carson is online now
Smoke Detectors In New Condo Not Connected.
Inspected a condo yesterday that is 3-4 years old. Stopped by the sales office to let them know I was heading over to start. Realtor came in from another office, saw me and said that she was surprised that someone would get an inspection on new condos since everything is taken care of by the maintenance department.
On top of other fit and finish and leaking faucet stuff I found that none of the smoke detectors are electrically connected. They just mounted the detector on the junction box and did not hook any of them up.
Nice
Michael Carson
Inspect It Right Home Inspections L.L.C.
www.inspectitrighthomeinspection.com
F.I.R.E. provides fireplace education, consulting services, fire investigation and litigation support across the United States.
Old 10-04-2009, 11:41 AM
Rick Cantrell Rick Cantrell is offline
Re: Smoke Detectors In New Condo Not Connected.
Around here smoke detectors are also required to be interconnected with battery backup.
Rick Cantrell
Old 10-04-2009, 12:45 PM
Raymond Wand Raymond Wand is online now
Well so much for the maintenance crew. Hope the place doesn't catch fire and someone is killed. Makes you wonder what is amiss in the other units.
Good find!
The value of experience is not in seeing much, but in seeing wisely. - Sir William Osler 1905
Old 10-05-2009, 01:54 AM
ben jacks ben jacks is offline
Nice
On top of that, the smoke alarm has no battery back-up, let alone an interconnecting parallel alarm conductor. I know WI State has adopted the smoke alarm 120Vac battery backup NFPA 72 Ch.11 requirement (1996) so this may have been a double violation. I notice that an AC whip is the interconnecting means and may not provide easy repair accessibility. I myself, would write it up requiring a hookup, but as a CYA just in case I would mention the missing battery and interconnecting conductor. A different smoke alarm may be needed. rbj
Old 10-05-2009, 05:05 PM
Quote:
I did write it up as requiring hookup according to local ordinances with applicable municipal inspection. The reason the battery is not there is because I had to remove it to get to the screw and loosen it. I did that so I could slide the detector aside to show the wiring along with the alarm for the picture.
Thank you for the info, I forgot the actual Ch. 11 requirement section.
Michael Carson
  #6 (permalink)
Old 10-05-2009, 07:57 PM
John Kogel's Avatar
John Kogel John Kogel is online now
You say the battery was installed so the unit would test ok, but not be hard wired???
Dang, now I'm wondering how many more are out there not wired just like that?????
  #7 (permalink)
Old 10-05-2009, 10:13 PM
Jerry Peck's Avatar
John,
If they are hard-wired in and interconnected as required, not being wired in and having a battery will not trigger the other smoke detectors - only that one will go off.
That should be enough to write the smoke detectors up, and have the installation checked and corrected, which would include the wiring.
If hard-wired and actually connected, but not interconnected, the same thing would happen - only that one smoke detector would go off.
  #8 (permalink)
Old 10-07-2009, 10:25 PM
John Kogel's Avatar
Quote:
John,
Thanks Jerry, that's ..........logical !!
Similar Threads
Dual supply for smoke detectors Bob Schlack Building Interior: Home Inspection and Commercial Inspection 10 08-21-2009 03:40 PM
Smoke Detectors on AFCI Bedroom Circuit Nick Ostrowski Electrical Systems: Home Inspection and Commercial Inspection 27 07-21-2009 11:45 AM
Proper test on Smoke Detectors daniel nantell General Chit Chat: Home Inspectors & Commercial Inspectors 4 05-08-2009 02:19 PM
How often should smoke detectors be replaced? Jerry Peck Electrical Systems: Home Inspection and Commercial Inspection 15 08-15-2007 07:00 PM
smoke detectors wayne soper Building Interior: Home Inspection and Commercial Inspection 4 04-12-2007 01:58 PM
vB.Sponsors
Ad Management by RedTyger
