Old 11-05-2009, 03:08 PM
Eric Kuzma Eric Kuzma is offline
Window safety glazing when adjacent to door
I'm wondering if someone can help me with an explanation and/or clarification for the code provision concerning window(s) needing to be saftey glazed when within a 24" arc of a door. More specifically the exception addressing locations where there is an intervening wall.
First question, what is the actual basis for this code provision?
Second the intervening wall, (I'm assuming refers to a wall perpendicular to the wall containing the wall and window, and between them) does there need to be an intervening wall on both sides of the wall (containing the window and door) or does one side suffice, and if so, does it matter which side?
Thanks.
I'm new to this forum, I searched for this topic and didn't find it specifically addressed, if it has been, could someone please direct me to the link.
Old 11-05-2009, 04:22 PM
John Arnold John Arnold is offline
Re: Window safety glazing when adjacent to door
Here's a thread from the archives:
Tempered Glass - InspectionNews.com
Illegal aliens have always been a problem in the United States. Ask any Indian. -Robert Orben, magician and author (b. 1927) / www.ArnoldHomeInspections.com
Old 11-05-2009, 04:25 PM
Here's another thread which may overlap/reference the first one:
Tempered Glass for Replacement Windows
Old 11-05-2009, 05:54 PM
Thank you for directing me to those previous posts,
I looked them over but didn't really see my question specifically addressed.
I'm probably splitting hairs, but without knowing the basis of the code requirement for window saftey glazing within 24" of a door, in trying to understand the exception which adresses intervening walls, it's not clear to me whether the intervening wall needs to be on both sides or if as the code states (singularly) on one side suffices.
Old 11-05-2009, 07:39 PM
Jerry Peck's Avatar
Quote:
The basis for the code is to include safety glazing in the area around the door in which you might: a) poke your hand through the glass; b) fall through the glass.
An intervening wall stops you from coming in contact with the glazing on the other side of that intervening wall - which mean there is no need for it to be safety glazing.
  #6 (permalink)
Old 11-05-2009, 11:18 PM
I'm sorry to persist on this.....
We just had this come up on a jobsite and there was never really resolution.
So, if the door is on an exterior wall, and swings indoors, and there is an intervening interior wall between the door and an adjacent window (within a 24" arc) but no intervening exterior wall, does the window still need to be saftey glazed?
Thanks again.
  #7 (permalink)
Old 11-06-2009, 04:48 AM
So, if the door is on an exterior wall, and swings indoors, and there is an intervening interior wall between the door and an adjacent window (within a 24" arc) but no intervening exterior wall, does the window still need to be saftey glazed?...
As Jerry said, the idea is to provide some protection in case a person tries to put their hand through the glass or fall through it, so, if there is no wall to prevent that from happening, interior or exterior, then the window needs to be safety glazed.
  #8 (permalink)
Old 11-15-2009, 05:19 PM
Jerry McCarthy's Avatar
Eric
Do you have a copy of the IRC 2009? If not, you should, assuming you’re in any state but California and then you would need the California Building Code 2007.
Back to the 2009 IRC, check section 308.4, and then note exceptions.
I'm not as patient or as thorough as EC Jerry, therefore do not cite codes word for word as I believe ever single serious home inspector should have a building code book collection and keep it current as they usually come up with new versions at every 3 year cycle.
This area you are asking about is a vital one in that its addressing occupant safety and that is probably the single most important area that home inspectors address – bar none !
Construction Consultant
  #9 (permalink)
Old 11-16-2009, 06:33 AM
Philippe Heller Philippe Heller is offline
Here is a good article with illustrations written by Douglas Hansen, author of the Code Check series.
http://codecheck.com/cc/images/Safet...gArticle07.pdf
Philippe Heller
The San Diego Real Estate Inspection Co.
www.sdinspections.com
IC Home Inspection Report Writing
Similar Threads
Glazing adjacent to stairways Stanley Piatkowski Introductions By New Members 3 10-08-2008 07:08 PM
Safety glazing next to a slider Dave Mortensen Building Envelope: Home Inspection and Commercial Inspection 34 09-24-2008 12:39 PM
Window glazing trim dan orourke Building Envelope: Home Inspection and Commercial Inspection 8 10-19-2007 06:17 PM
Safety Glazing Jeff Gainey Building Interior: Home Inspection and Commercial Inspection 11 07-23-2007 05:53 PM
Window Glazing Trim John Stephenson Building Envelope: Home Inspection and Commercial Inspection 3 06-01-2007 12:29 PM
vB.Sponsors
Ad Management by RedTyger
