In New construction the designing engineer should look at it if its anything more than RTS cracking...which this sounds like it is.
A "repair" may not be justified as yet but the cause should be identified so that the probability of worsening can be assessed. Certanily not off to a good start!
Not usually foundation company repair issue.If anything it would be SE. A lot of times they do not compact soil properly after being disturbed for foundation construction. It then can settle and get worse as Phil said.
I have seen them settle enough that you could place another 4 inch slab on top of settled one.
Look on the edges for the chalk line that was top of slab. Has slab settled below this line. Of course you have to verify slab was placed to this line, usually identified by concrete from slab.
Is this a foundation with slab poured between walls or slab on grade/monolithic?
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/building-interior-home-inspection-commercial-inspection/1785-cracks-garage-slab.html
All Rights Reserved. Hann Tech Marketing Link / InspectionNews.com / InspectionNews.net - No part of InspectionNews.net may be reproduced in any way, or by any means, without the prior written permission of InspectionNews.net. Use of any index or listing Software for the purpose of constructing a mailing list, creating promotional materials or producing a printed or electronic catalog of any kind is expressly forbidden without the prior written permission of InspectionNews.net - All text, graphics and design on InspectionNews.net is copyright by Hann Tech Marketing Links. Ad Management by RedTyger
