Old 07-10-2007, 11:37 AM
Roni Litmanovic Roni Litmanovic is offline
Water penetration wood flooring
We did an inspection yesterday in an unoccupied 4000sq2 apartment, where we found water stains on a section of some woodflooring, adjecent to a wall which also had water stains. We were told by the seller realtor that it was due to condensation caused by the apartment below, which apparantly keeps their AC unit on all day, causing the unoccupied, humid woodfloor to condense. The wood flooring is a laid a top a plywood sheet, which is laid on the concrete structural flooring. IS THIS POSSIBLE???
Old 07-10-2007, 12:00 PM
John Arnold John Arnold is online now
Re: Water penetration wood flooring
Sounds bogus to me.
Old 07-10-2007, 02:29 PM
wayne soper's Avatar
wayne soper wayne soper is online now
Was it wet? Take a picture. Have the broker sign the picture stating whatever she says is the cause in writing. That will get a "well your the home inspector" and you answer. " yes, prescisely" Sherlock!
Old 07-10-2007, 02:58 PM
Phillip Stojanik's Avatar
Phillip Stojanik Phillip Stojanik is offline
Quote:
I guess anything is possible but the apt. below would have to be as cold as a meat locker and have a significant amount of air exhange going on between the two units. Personally I would look for other possible explanations rather than accept the one given by the seller's agent.
By the way, was the area actually wet or were these just old dry stains?
Old 07-10-2007, 04:14 PM
Scott Patterson's Avatar
Dog pee! Cat pee! Human pee! Watering plants!
The above list would be my target suspects. Dry urine will still attract moisture due to the salts in the urine making urine hygroscopic.
Scott Patterson
  #6 (permalink)
Old 07-10-2007, 04:35 PM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
If there is water staining on the wall nearby, there could be your source for the water on the flooring.
We find water stains on walls are usually caused from some type of leakage at the roof. Most common is leakage around the sewer vent pipes.
Was there a laundry room near this area, a bathroom where a toilet or tub could have over-flowed. The possibilites are many.
The idea of it coming from below as someone else said sounds bogus.
Remember, an agent most likely will tell you anything to sell a place. Never bank on their information but base your findings on your inspection. Use the force.
Rick Hurst
Home Works Inspection Co.
5 out of 4 people have trouble with fractions
  #7 (permalink)
Old 07-11-2007, 03:10 AM
Brian M Jones Brian M Jones is offline
Let me see if I got this straight.....
wood floor on top of plywood on top of concrete slab;
A/C unit running constantly on floor below, supposedly causing water stains on floor and wall in above unit;
If I read this right, my first question would be: Did the laws of gravity get suspended for just this apartment/condo unit?
Second question would be; could the agent send me some of those drugs she's on?
  #8 (permalink)
Old 07-11-2007, 03:59 PM
Thanks.....
Similar Threads
Fuzzy wood under front porch Terence McCann Exterior Systems: Home Inspection and Commercial Inspection 8 02-29-2008 07:29 PM
Fireplace Wood to Gas David Banks Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 4 12-02-2007 08:24 PM
Deck flooring dan orourke Exterior Systems: Home Inspection and Commercial Inspection 4 06-20-2007 09:53 PM
Exposed wood joist in return air John Tullous Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-08-2007 06:27 PM
Wood Burning Fireplace Dale W. Feb Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 12 04-16-2007 02:08 PM
vB.Sponsors
Ad Management by RedTyger
