Old 09-18-2007, 01:34 PM
Eric Laney Eric Laney is offline
Drilled holes along baseboard
Did a foreclosure today, all along bottom of sheetrock the baseboards were removed and about every 8 inches was a 3/4" drilled hole just through the sheetrock. The home had undergone foundation leveling (slab), and had also been flooded by a plumbing leak. Anyone know what the holes are for , termite treatment, mold abatement, part of leveling process?
Old 09-18-2007, 02:08 PM
Rick Hurst's Avatar
Re: Drilled holes along baseboard
Eric,
I would guess that those holes were drilled into the wall for ventilation after the flood you mentioned.
A restoration company did this same thing to our salon a fews years ago after a neighbor in the building had a water heater leak.
They placed fans and moisture removal equipment in the salon for like a week to help removed the moisture from within the wall cavities.
Rick
Old 09-18-2007, 03:03 PM
Scott Patterson's Avatar
Yep, them be flood holes!
Scott Patterson
Similar Threads
Weep holes Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 2 08-19-2007 04:49 PM
No Weeps Holes Erol Kartal Exterior Systems: Home Inspection and Commercial Inspection 19 08-16-2007 11:14 AM
Weep Holes Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 13 05-30-2007 04:23 PM
vB.Sponsors
Ad Management by RedTyger
