Old 10-17-2007, 04:44 PM
Clay White Clay White is offline
Powdery substance on window sill
Old 10-17-2007, 04:47 PM
Re: Powdery substance on window sill
Dirt.
Everything that washes down from above collects on the ledge until it dries up and leaves the dirt behind.
Did you taste it?
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 10-17-2007, 04:48 PM
Rick Hurst's Avatar
Probably a pest control supply dust for carpenter ants.
Some would use a boric acid base but it wouldn't be dark like that.
The more I look at it, it looks like dirt as Jimbo said.
Old 10-17-2007, 08:03 PM
It's on the inside, stepped up, part of the sill where the window closes to, so it's basically 'out of the weather'.
But, is there a rubber/vinyl/foam/weatherstrip along the bottom of the bottom sash which closes there?
If the 'powder' was 'fine granules', did they roll around like ball bearings? If so, possibly drywood termite frass (but that is an unusual location to find it).
Old 10-17-2007, 08:15 PM
If these threads were not posted by two different people in two different locations, I'd have guess that this was the inside view of this window.
Window Weep holes
But it's probably similar, even being two different houses.
Similar Threads
Substance on roof Jeff Eastman Roofing System: Home Inspection and Commercial Inspection 3 09-29-2007 03:04 PM
Staining on window sill dan orourke Building Interior: Home Inspection and Commercial Inspection 7 09-26-2007 10:40 PM
white powdery deposits...??? Ron Bishop Sub-Structure: Home Inspection and Commercial Inspection 25 08-30-2007 10:12 PM
Window Hazards Jim Dull Building Envelope: Home Inspection and Commercial Inspection 5 06-30-2007 06:10 PM
outside my window John Arnold Tools and Equipment 6 05-07-2007 06:19 AM
vB.Sponsors
Ad Management by RedTyger
