Old 11-05-2007, 04:45 PM
Hall width to stair guardrail
Home inspection
Old 11-05-2007, 05:21 PM
Gunnar Alquist's Avatar
Re: Hall width to stair guardrail
Jeff,
I assume that this is the same house as the one with the difficult water heater access in the laundry area. As with the water heater access, I would certainly talk about your access, installation and fall concerns. Given that the laundry appliances will have to be moved in, then moved out when the water heater needs to be replaced and then back in again.
The apostrophe troll.
Old 11-05-2007, 05:30 PM
Rick Hurst's Avatar
I always make mention too that there should be a drain pan with a drain below the laundry machine when they are on the second floor. This is something many times overlooked.
As far as the clearances, I've got washers and dryers in such tight spots. You could even pull off those bi-fold doors at the hinges to give yourself some more room.
Plus 4 on those railings I'd bet too.
Rick
Old 11-05-2007, 06:11 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Quote:
Originally Posted by Jeff Eastman View Post
From the laundry door to the 2nd level stairway guardrail , I measured approximately 28". Should it not be 3 feet? !
Jeff,
IRC 2003 R311.3 The minimum width of a hallway shall be not less than 3 FT.
Billy J. Stephens HI Service
Home inspection
Similar Threads
Door (?) opening over stair Clay E White Building Envelope: Home Inspection and Commercial Inspection 2 09-23-2007 08:20 PM
Porch Guardrail Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 5 06-03-2007 03:31 PM
New construction - stair step cracks Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 2 06-02-2007 07:58 PM
Opening at bottom of guardrail dan orourke Building Interior: Home Inspection and Commercial Inspection 5 05-07-2007 07:29 PM
vB.Sponsors
Ad Management by RedTyger
