Old 11-05-2007, 04:47 PM
Access to water heater closet
Home inspection
Old 11-05-2007, 05:18 PM
Gunnar Alquist's Avatar
Re: Access to water heater closet
Jeff,
I think it could be argued either way as to whether or not it is a violation, if it were me, I would certainly mention the restricted access and not really care about code.
The apostrophe troll.
Old 11-05-2007, 05:38 PM
Rick Hurst's Avatar
With that vent in the WH closet door and being in the laundry room, its also going to suck lint into the closet which is going to be a problem.
Is this a KB by chance?
Old 11-05-2007, 06:07 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Quote:
Originally Posted by Jeff Eastman View Post
the washer will block access to the water heater closet. Is this a code violation, if so what is the code?
Jeff,
IRC 2003 P2801.3 Location, Water as to provided heaters and storage tanks shall be located and connected so as to provide observation,maintenance,servicing and replacement.
Billy J. Stephens HI Service
Old 11-05-2007, 07:06 PM
Quote:
I'm assuming that is for a gas water heater, and that the vent in the door is a combustion air vent ... in which case the clothes washer will block that vent - not to mention (as others have stated) block access to the water heater.
  #6 (permalink)
Old 11-06-2007, 02:40 PM
Kevin Barre Kevin Barre is offline
At a minimum, it's a phenomenally poor design. If I were the buyer, I'd at least insist on windows in the door so I could monitor what was going on in there.
  #7 (permalink)
Old 11-06-2007, 02:59 PM
Rick Hurst's Avatar
Kevin,
If you asked that builder to put glass in the door, he'd forget to use safety glass.
  #8 (permalink)
Old 11-06-2007, 03:35 PM
Quote:
Originally Posted by Billy Stephens View Post
Jeff,
Quote:
Assuming the washer /dryer is able to be installed in this laundry room, the washer will block access to the water heater closet. Is this a code violation, if so what is the code?
Jeff,
Glass might meet the observation requirement. But would not meet the other three requirements stated in the code. This setup would allow either the Washer to be installed or the Water heater not both.
Similar Threads
Attic Water Heaters - Scuttlehole Access only Steve D'Gerolamo Plumbing System: Home Inspection and Commercial Inspection 28 10-27-2007 06:41 PM
Central A/cC Unit & Gas Water Heater Same Closet? Sabrina Roper Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 13 09-12-2007 02:48 PM
Central A/C Unit & Gas Water Heater Same Closet? Sabrina Roper Plumbing System: Home Inspection and Commercial Inspection 2 09-05-2007 11:29 AM
Electric water heater in bedroom closet? Trey Humphreys Plumbing System: Home Inspection and Commercial Inspection 0 06-07-2007 02:20 PM
Water closet Mike Schulz Plumbing System: Home Inspection and Commercial Inspection 9 04-14-2007 03:49 PM
vB.Sponsors
Ad Management by RedTyger
