Old 11-16-2007, 11:24 AM
Dennis R Dennis R is offline
Universal Brand Windows
9 month old 4 story condo building, 3rd floor unit.
Concrete floors with carpeting and hardwood on them.
FHA heat by gas, no humidifiers in use. No unusal interior sources of moisture.
Exterior temperature at time of inspection 46 F.
Client has lived there for several months and has complained to the builder about wetness around the windows. Client said he noticed the stain on the baseboard after a rain storm last week.
Lots of condensation found at the perimeter of the windows and water ponding found on the window sills. They don't drain very well. No visible weep holes and storm window sashes act as a dams.
Anyone familiar with these Universal Brand windows?
http://www.ablehomeinspection.com/in...nphotos1-4.pdf
http://www.ablehomeinspection.com/in...nphotos5-8.pdf
Old 11-16-2007, 12:33 PM
Fritz Kelly Fritz Kelly is offline
Re: Universal Brand Windows
They use them quite a bit here, they are bottom of the line. One group of condos here has had to replace many of them. I was calling it out as improper flashing and was informed by the association that it was the windows themselves, not the flashing, but, when I saw a couple removed, there was no flashing, just stucco paper up to the frame. Bottom line is, I think it could be the windows but could also be flashing. The builder should have the window rep check them out.
Old 12-02-2007, 09:00 AM
Alton Darty Alton Darty is online now
These would appear not to have any type of thermal break between the inner and outer portions of sash. Cold outer section -thermal break +warm inner section =condensation. Oh, could be that inner section is cold & outer section is warmer.
These would appear to be a very inexpensive window, you will probably see a lot of other problems with these, so they should still be fairly easy to spot even if the weather conditions have been pretty moderate. Plus stains or other evidence of moisture intrusion should be present.
Similar Threads
Brand new interested in the business. hello LEIF KARLSSON Introductions By New Members 8 01-20-2008 10:34 AM
Vinyl Windows David Banks Building Envelope: Home Inspection and Commercial Inspection 7 07-30-2007 08:19 PM
Window brand needed Eric Laney Building Interior: Home Inspection and Commercial Inspection 2 05-13-2007 06:11 AM
From the old board, Stairway windows? Tim Moreira Building Interior: Home Inspection and Commercial Inspection 1 04-04-2007 11:03 AM
vB.Sponsors
Ad Management by RedTyger
